Hi Tom,
Yes, I do have access to the Yahoo group although I rarely post there, so I found your photos. I did wonder if the plate was originally a rectangular shape and your shot confirms that. Going on the oxide jacking between the outer sill & floor joint mine was only held on 2 rivets which is the reason I cut away the lower edges.
I've got to say that restoration you show has incredible attention to detail. One thing you can be sure of is that Lotus wouldn't have paid as much attention to painting the underneath & wheel arches as you have. I'm not even sure mine has any paint underneath apart from the wheel arches.
For anyone in the UK contemplating similar ideas, I've added a photo of the current installation. It seems ok, I'll live with it for a while and post up if any more changes are needed.
In the end I decided not to mount the reel in exactly the same position as the OEM ones for two reasons; firstly the detailed instructions with the reels indicated that a pull at 90deg was needed to lock the belts (so they wouldn't have operated "at any angle" as originally advertised
) but more significantly the steelwork holding the reels in place is noticeably thinner than the pictures Joji posted. I had concerns that mounted in the same manner the steel would buckle under load, and if that let the reel break free you can imagine that's "game over" time.
I lost a very small amount of rearwards seat adjustment, probably less than an inch, so it doesn't concern me that greatly. The angle of the belt retracts easily and slips nicely away between the seat bolster & carpet, I pulled it out of line here so you can see how the reel is mounted. Two bolts, above & below with the belt guide also mounted on the top bolt and taking all of the forwards loading. Hidden away is a steel reinforcing plate to ensure that the thin steel is under shear & not bending loads as in the sketch.
