Author Topic: Hub cap removal ?  (Read 1317 times)
Hub cap removal ?
« on: Tuesday,February 24, 2015, 04:54:44 PM »
I have no idea how to remove the cap on the hub. It doesn't have the typical lip that you get behind and pry from.
Re: Hub cap removal ?
« Reply #1 on: Tuesday,February 24, 2015, 05:17:24 PM »
Try tapping the hole for 10-32 or 10-24 thread. Screw a long bolt of the correct size into the hole and it should push the dust cap out. To make sure it works in the future, I think it's a good idea to tack a small nut of the right thread inside the cap so you don't have to rely on the threads in the cap next time. I mentioned this to Serge a while ago and he plans using a wood screw in a similar manner. I've never tried it but I'm sure it works and it is easier than tacking the nut in the cap!
« Reply #2 on: Tuesday,February 24, 2015, 05:28:25 PM »
Thanks.
« Reply #3 on: Wednesday,February 25, 2015, 05:39:03 AM »
A small hole in the middle, and screw in a self tapping screw, and this applies even pull all around, and the grease cover will come straight off.
« Reply #4 on: Thursday,February 26, 2015, 08:14:00 AM »
The coarse screw worked on one side. On the other, the coarse screw just pulled out, went to a larger one and the same. Welded a nut on the end and it came right off.
« Reply #5 on: Thursday,February 26, 2015, 08:33:34 AM »
Congratulations! I never understood the appeal of that design.
