Author Topic: Pulley  (Read 2198 times)
Pulley
« on: Sunday,August 26, 2012, 03:57:09 PM »
Hey fellers,
Which supplier sells the alumninum pulley that attaches to the cam on a TC?  Now the question is, do I want the one with the many holes or the solid one.  I'm in the U.S.
My stock pulley has a wobble.   That is not good.  Plus, who needs the weight of steel when aluminum is available.
Mike
Re: Pulley
« Reply #1 on: Sunday,August 26, 2012, 04:46:37 PM »
r.d. enterprises sells the aluminum alternator pulley you're talking about (http://www.rdent.com/ search on Europa | Europa Parts). As for which one you should get, you need to make that decision...
Offline Pete Gossett
Re: Pulley
« Reply #2 on: Sunday,August 26, 2012, 07:25:44 PM »
The one with the holes is a bit lighter, and that lightess is greater an the perimeter. Is that worth ~$145 to you?
Honestly I wish they offered it with 1"-1.5" smaller diameter. Anything to reduce rotating mass should be quite beneficial.
