Author Topic: Logic Box  (Read 2834 times)
Offline exarkun1178
Logic Box
« on: Saturday,November 15, 2014, 03:15:44 PM »
The last hanging chat on my restoration is the logic box.  How hard is the job?  The shop doing the work doesnt really want to do it.  maybe that they are sick of looking at the car?  anyways.  ordered it from Ray today.
Re: Logic Box
« Reply #1 on: Saturday,November 15, 2014, 10:21:55 PM »
It's not "hard" at all: you just hook it up as outlined in the wiring diagram.
Re: Logic Box
« Reply #2 on: Saturday,November 15, 2014, 11:52:50 PM »
errr, what's a "logic box" ?
(struggling to find anything like "logic" in a 60s Lotus   :)   )
Offline ron parola
Re: Logic Box
« Reply #3 on: Monday,November 17, 2014, 03:39:58 PM »
"logic box" controls seat belt light or buzzer on federal cars, something that you guys luckily missed out on. Better yet if you had an MGB it had a diode from it's box to the ebrake lever. WHEN not IF the diode  failed (shorted not open) then, with the ignition on, you pulled up on the ebrake the starter would motor along, sometimes starting the car.... guess how I know! Cheers rp
Re: Logic Box
« Reply #4 on: Monday,November 17, 2014, 09:58:37 PM »
Park brake starting the engine   :huh:    in the words of Mr Spock, "that is NOT logical"......   :)
Thanks for the info Ron, it sounds like an excellent opportunity to "add some more lightness".....
Offline blasterdad
Re: Logic Box
« Reply #5 on: Tuesday,November 18, 2014, 05:17:32 AM »
I've added a lot of "lightness" over the years... Still regret not unhooking the one in my F150 while I replaced the heater core.  :headbanger: Damn thing drives me nuts!
Offline exarkun1178
Re: Logic Box
« Reply #6 on: Saturday,November 22, 2014, 01:12:11 PM »
Update
Turns out th elogic box was both cheap ($150) and not to bad replacing (~1 hour)  For the first time since 1989 all the lights work!
Re: Logic Box
« Reply #7 on: Saturday,November 22, 2014, 04:57:39 PM »
That HAS to feel good! Small pain in your wallet and all the lights working! Just don't tell the ghost of Joseph Lucas!
Re: Logic Box
« Reply #8 on: Saturday,November 22, 2014, 11:00:21 PM »
All the lights working ?
On the same day ?
On a British car and a Lotus one at that ?
oh dear, this isn't going to end well my good man.    You're going against Nature and years of tradition now......  is that smoke I can smell ?
Offline exarkun1178
Re: Logic Box
« Reply #9 on: Sunday,November 23, 2014, 05:34:54 AM »
I agree im likely at the high spot in the cars life.
Offline blasterdad
Re: Logic Box
« Reply #10 on: Sunday,November 23, 2014, 05:54:14 AM »
Is the "logic box" just for the seat belt system as ron parola stated, or does it do other things as well?...
Offline exarkun1178
Re: Logic Box
« Reply #11 on: Sunday,November 23, 2014, 03:20:09 PM »
The logic box in the S2 controls the turn signal lights, break lights and running lights.  Unlikely my car has a seat belt sensor.
Offline blasterdad
Re: Logic Box
« Reply #12 on: Sunday,November 23, 2014, 06:29:07 PM »
Thanks for the info, havn't tried any of my lights yet, but good to know when I do. ;)
Re: Logic Box
« Reply #13 on: Monday,November 24, 2014, 01:14:19 AM »
There's a difference between the DB10 relay for brake and indicator lights and the logic box used in late TCS for seat belt, warning etc.
Don't confuse them. I'm pretty sure the S2 doesn't have a logic box, and I built my own DB10 for about $15.
« Last Edit: Monday,November 24, 2014, 01:18:41 AM by Roger »
Re: Logic Box
« Reply #14 on: Monday,January 11, 2016, 12:11:10 PM »
I am now finishing the wiring for 3755R which conforms to the later circuit diagram, so the starting number of 3924 is incorrect.
Does anyone actually know what the "logic box" is for?
Is it just about 12 open female terminals in a circular connector, or is anything actually plugged in to it, which I am missing.
I just cannot work out how the starter relay ever worked, as according to the wiring diagram, there is no direct connection from the ignition switch in start mode, via the white and red wire, to the starter relay,which triggers the starter solenoid.
Alex in Norfolk, the home of Lotus.
