Author Topic: Renault NG3 Gearbox  (Read 3753 times)
Offline skoolsen
Renault NG3 Gearbox
« on: Sunday,November 09, 2014, 09:01:32 AM »
Hi
What is the value of a Renault NG3 079 gearbox in good condition.
Thinking about selling one of mine.
« Last Edit: Sunday,November 09, 2014, 09:03:07 AM by skoolsen »
0581R
Offline blasterdad
Re: Renault NG3 Gearbox
« Reply #1 on: Sunday,November 09, 2014, 09:53:20 AM »
« Reply #2 on: Sunday,November 09, 2014, 11:02:23 AM »
There is some prep work that must be done on the based on this: http://www.greytower.com/jon/lotus/europa/gearbox/gearbox.html
Part of what is described in that link is converting it to a side shifter and you end up with pretty much what Richard at Banks sells (see below). I believe that some have fashioned cable shifters with the original rear shift configuration. There should be plenty of discussion about ways to do this on the lotuseuropa yahoo group (if you own a Europa, you should be a member).
Banks also sells prepared NG3s including a kit for the linkage and all mounting hardware. Look here: http://www.parts.banks-europa.co.uk/orders_frame.htm and choose 'Gearbox'. This is the route I took and it worked out very well.
In the end, it pretty much depends on how much fabrication you want to do.
Good luck and remember to post pictures!
« Reply #3 on: Sunday,November 09, 2014, 11:16:26 AM »
I picked up a brand new NG3 for $500 USD around a year ago here in So Cal.
Offline skoolsen
« Reply #4 on: Sunday,November 09, 2014, 11:59:31 AM »
OK Thank you, so no UN1 prices then.
0581R
« Reply #5 on: Sunday,November 09, 2014, 12:32:52 PM »
Oops!! I didn't read the OP's post well and thought he was looking for one.    :headbanger: :headbanger:
