Thanks! I'm about 6’2, so the bubbles were definitely a necessity. With the cage in place, the seat has to be about 6“ further forward than optimal, so that combined with the rake left nowhere for my knees.
Agree that oil temp was a bit high - very hot day, and even though I installed an oil cooler, it needs some ducting. It's located in the passenger side of the rear grill. I've gotten used to the gauges all pointing to roughly two o'clock when normal.. Probably should point them up.
Stefan - I've been following your posts for a while. You guys have a very neat Europa! I like your hose - in America we're not allowed to race with side windows, so I feel lucky! Let's see what kind of info I can come up with:
The engine is an amalgamation- it's an 821 "block" with bored sleeves. 807 pistons from Venolia machined to be about 13:1 compression, 807 rods and oil pump and an 843 Crossflow head with big valves. Estimate about 150 Bhp. (The Elan I beat had about 190 - Haha!)
Weight is about 1340 pounds. The car has the stock chassis, and the Banks cage isn't light.. Suspension setup is stock, but with AVO adjustable racing shocks, thick front swaybar and an adjustable custom rear bar, as well as adjustable lower links for camber change.
Fuel cell is mounted in the front luggage tray.
Here are some more photos (from a couple of months ago) not included in the link I shared:
