Author Topic: LED conversion Full Car  (Read 1594 times)
Offline exarkun1178
« on: Sunday,May 04, 2014, 07:03:04 AM »
I wanted to sum up my LED conversion for the Europa.  I have an S2.
After my father picked up his A8 with LED headlight I spent a few mins on YouTube looking up LED headlights and was surprised Audi was not the first.  I knew there were LED alternatives to smaller applications like brake lights and turn signals, but was surprised to find headlight solutions.  This got my gears turning.
I saw two major benefits
•   Much better light output then the current incandescent
•   Much less draw on the electrical system-  1.80amps (low beam), 3.60 amps (high beam)
Didn’t take long to decide on a product from Truck-Lite: Truck-Lite 7" round phase 7  (~$400)
While there are other solutions my research determined the phase 7 to be the best of all things.
After receiving the units I ask myself an obvious question, why not all the other lights in the car?  The following is a list of bulbs now installed in my car:
Headlights
From Discount Fleet Supply Truck-Lite 7" round phase 7 (~$400) (1300 Lm)
Dashboard:
From Moss Motors the 6 gauge lights, Gauge lights   (~$9 each)
From Super Bright Lights BA7S (~$1 each)  These are for the assorted check lights on the dash, 1 green, 1 blue, 2 amber, 1 red.
Front Turn signals:
From The Grafx shop Dual-Color 60x SMD LED Switchbacks White/Amber (~$30) (300 – 600 Lm). What I like about these, they are very bright and they stay white, like DRL and when you signal, they flash amber white amber white.  In conjunction with these I bought, from R&D the clear turn signal lenses (~$24)
Brake lights:
From Super bright lights 1157-RHP28-T Red (~$50) (550Lm)
Back up lights:
From Super Bright Lights 4410-NW9 Natural White (~$2.50 each) (40 Lm)
Cabin light:
From Super Bright Lights  LED3710-WWHP6 Warm White (~$15) (95 Lm)
Offline exarkun1178
Re: LED conversion Full Car
« Reply #1 on: Sunday,May 04, 2014, 07:07:19 AM »
Looks like the hyper links did not work,
Headlights
From Discount Fleet Supply http://www.discountfleetsupply.com/tlc27270c-p.html (~$400) (1300 Lm)
Dashboard:
From Moss Motors the 6 gauge lights, http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=118376   (~$9 each)
From Super Bright Lights http://www.superbrightleds.com/moreinfo/bayonet-bulbs/ba7s-led-bulb-1-led/10/ (~$1 each)  These are for the assorted check lights on the dash, 1 green, 1 blue, 2 amber, 1 red.
Front Turn signals:
From http://www.thegrafxshop.ca/1157 Dual-Color 60x SMD LED Switchbacks White/Amber (~$30) (300 – 600 Lm). What I like about these, they are very bright and they stay white, like DRL and when you signal, they flash amber white amber white.  In conjunction with these I bought, from R&D the clear turn signal lenses (~$24)
Brake lights:
From Super bright lights http://www.superbrightleds.com/moreinfo/s-series-bulbs/1157-led-bulb--dual-intensity-28-high-power-led-/1644/ (~$50) (550Lm)
Back up lights:
From Super Bright Lights http://www.superbrightleds.com/moreinfo/festoon-series-bulbs/578-led-bulb-9-led-festoon/237/ (~$2.50 each) (40 Lm)
Cabin light:
From Super Bright http://www.superbrightleds.com/moreinfo/festoon-series-bulbs/3710-led-bulb-6-smd-led-festoon/661/ (~$15) (95 Lm)
Offline exarkun1178
« Reply #2 on: Sunday,May 04, 2014, 07:09:58 AM »
In some cases there are less expensive options.  i was less concerned with price and more concerned with Lumens (light output level)
