Author Topic: VDO Speedometer & Tachometer  (Read 1424 times)
Offline lior_baruch
    • Back On Two
« on: Monday,April 21, 2014, 11:56:26 AM »
Hi,
I'm looking to buy a new set of VDO speedometer and Tachometer for my S1 (currently I got no gauges at all...)
Anyone know which ratios or special things I need to know to match a VDO to the Lotus?
Lior
Dreams are meant to come true
http://www.backontwo.com
Offline Mecky
    • Lotus Europa Racing
Re: VDO Speedometer & Tachometer
« Reply #1 on: Tuesday,April 22, 2014, 09:29:38 AM »
I use fuel and oil pressure gauges made by VDO and you need the matching sensors for them. I don't know, if a VDO speedo fits with the tachometer shaft. The diameter is 80 mm.
VDO are well made quality products and worth the money they cost.
« Reply #2 on: Tuesday,April 22, 2014, 02:43:37 PM »
Are you looking at electronic bits for both. I know VDO make electronic ones which can be self calibrated, used one in my Westfield.  A lot easier to fit a sensor somewhere than sort out the mechanics of a cable driven speedo.
