Author Topic: Gearbox 7700 598 262  (Read 1854 times)
Offline pakorrete
« on: Tuesday,April 15, 2014, 06:35:11 AM »
Hello, I have a renault 807-03 R16TS engine in my europa, looking gearbox 5 speed, I found a re 7700 598 262. Coming of a petrol R18 or R Fire. Is pug & play with my engine what is it 5 speed? my original gearbox is 7700 510 333
Thank you very much and sorry for my English difficult
Re: Gearbox 7700 598 262
« Reply #1 on: Tuesday,April 15, 2014, 01:31:36 PM »
The number you posted are probably stampings on the gearbox casing not the type of gearbox that you have. Gearbox type is generally a round metal tag on the end of the gearbox. Take a look at the website from Dave Syer. Should give you an idea of what you have and what gearbox will fit.
http://www.syer.net/donor_cars.htm
Fallbrook, Ca
« Reply #2 on: Monday,November 07, 2016, 09:22:33 AM »
Here are photos of 3 different types of gearboxes that I have accumulated.
I know gearbox 1 is a 5 speed, from the ball bearing thing mounted on the back.
I have no idea what gearbox 2 and 3 are, and none have any ID tags.
Can anyone identify gearboxes 2 & 3 please?
« Last Edit: Monday,November 07, 2016, 09:25:59 AM by 4129R »
« Reply #3 on: Monday,November 07, 2016, 11:25:40 AM »
Transaxle 1 = 365
Transaxle 2 = 352
Transaxle 3 = 352
« Reply #4 on: Monday,November 07, 2016, 11:31:43 AM »
But 2 & 3 are slightly different apart from the completely different bell housings.
Presumable different versions of the same basic 4 speed gearbox.
Offline Lotus 47
« Reply #5 on: Monday,November 07, 2016, 02:01:35 PM »
http://lotus-europa.com/0119q/chassis%20rear.jpg
This is my 395 from and R18 petrol engine car. The rusty bit on the RH rear of the box is an extension I bolted on to make the shift work.
How to install a 5 speed (a 395 that is.....)
http://lotus-europa.com/0119q/395_install.html
Offline Lotus 47
« Reply #6 on: Monday,November 07, 2016, 07:46:18 PM »
Gearbox #2 has a Renault bell housing to suit an 697/821/807 engine.
Gearbox #1 & #3 look link Lotus bell housings for the Twincam
« Reply #7 on: Tuesday,November 08, 2016, 02:59:58 AM »
And the ball bearing thingy doesn't identify 5 speed. 352s have it as well.
Offline pboedker
« Reply #8 on: Wednesday,November 09, 2016, 12:20:50 AM »
If the detent cam has one notch, it's for a 4 speed (352). If it has two - like the photo - it's for a 5 speed (365). 8)
Peter Boedker
3904R Special
Denmark
