Author Topic: Dodge engine ohaul  (Read 221 times)
Dodge engine ohaul
« on: Friday,April 04, 2025, 05:53:29 PM »
 How deep should I go into an engine that has 185k miles on it? I pulled the engine for overheating and oil leaks from the backside of the engine. No burning oil or smoke.
  I noticed I can buy an overhaul kit which includes piston rings bearing gaskets timing gears and guides and tensioner for $469.  Available std 10- 20 or 30 over. 2.4L 16 valve 2014 engine.
 Do you think it’s overkill to do the pistons and rings? There is no ridge in the liners. I’ll pull the valves and check them .
  Pulling the head was a learning process having T55 torx bit bolts down 2” into head  so I had to purchase a 6”. 1/2 drive to break the heavily torqued bolts.
Offline cazman
Re: Dodge engine ohaul
« Reply #1 on: Saturday,April 05, 2025, 02:52:06 PM »
Just Hone and re-ring?
1973 Europa TCS
« Reply #2 on: Monday,April 07, 2025, 04:13:02 AM »
  Cazman, ( great name btw)
  That’s what I was thinking 👍👍.  New bearings too.
Offline cazman
« Reply #3 on: Monday,April 07, 2025, 04:29:54 AM »
LOL
1973 Europa TCS
