Author Topic: Cutting fiberglass  (Read 239 times)
Offline kram350kram
Cutting fiberglass
« on: Thursday,March 27, 2025, 08:28:57 PM »
Need to cut some fiberglass panels that are finished painted. The cuts needed are both straight and curved. Don't want to mess up the paint. Any thoughts on a way to do so...very fine scroll saw?  Have access to both sides of the panel.
Re: Cutting fiberglass
« Reply #1 on: Thursday,March 27, 2025, 09:39:06 PM »
Any kind of saw will chew the paint a bit. Laser or water jet would be the cleanest. Barring that, tape the cut line and cut down into the paint surface to reduce chipping. As you said, a very fine scroll saw.
« Reply #2 on: Friday,March 28, 2025, 03:27:59 AM »
I have used an angle grinder with a thin blade for cutting metal, and it cuts very cleanly.
« Reply #3 on: Friday,March 28, 2025, 03:53:36 AM »
I used the same when I cut a vent hole in my finished hood.
