Well, went to look at the car today (45 minutes away), overall looked like a good driver's car. Quick drive, steering felt tight, no rattles - surprised, suspension felt good, all gauges worked, windows worked. Has been garage kept under a cover since he owned it, next to a 70's TR6 also under cover, no oil or residue on garage floor. His other cars both newer Land Rover Defenders. He jacked the front right side up about 4" - took some pictures - on 1 of the pictures is that rust on the front frame? or rust on something else - I didn't want to get under the car
History per owner - bought the car 6 years ago in New Jersey from Aston Matin dealer, engine was redone 2023, paperwork forth coming, water pump & clutch replaced 2023 parts from RD Ent. original type. Shocks didn't know - he didn't replace. Repainted prior to his ownership - It was certainly a passable paint job, nowhere near the best but there were no paint cracks anywhere!, door hinges were replaced with adjustable (?) no radio. Original dashboard was re-veneered, Interior was clean, dash pad looked good, whatever was hanging in pictures wasn't present today and all gauges worked.
Looked up registry see below - seems that there are 2 cars with same#, i believe it's the 72mm2467r.
72062464R Bruce Elrick Surry B.C. As invoiced:
Last Updated: 9/14/10 British Columbia Vin Number: 74/2464R
Canada Date Built: 6/1972
Date Invoiced: 6/30/1972
Engine #: S27083
Transmission #: 4 Speed
Original color: L13 - Pistachio Lime Green
Condition:
Current color: Regency Red
A project, but making good progress. A lot of the parts have already been purchased and its a matter of a bit of paint, cleaning up and some rewiring. The body is off the already 99% completed chassis. motor is a twin cam big valve, dual stromberg varity. 4 speed gearbox.
72mm2467R Andrew Orourke New York As invoiced:
Last Updated: 4/10/14 USA Vin Number: 74/2467R
Date Built: mm/1972
Date Invoiced: 7/6/1972
Engine #: S27064
Transmission #: 5 Speed
Original color: L11 - Regency Red
Condition:
Current color: Red
PO: Michael Colavito
Good/restored
