Last autumn I lost compression on cylinder 1 and 2
cylinder 3 and 4 had 150 1 and 2 almost nothing so I put some oil in the cylinder and the compression was 150 on all cylinders so I figured broken compression rings
I removed the head and yes it’s broken rings but no damages to the cylinder
Now my question is can I hone these cylinders they are not damaged I would change the gaskets and the ring keep the cylinders and pistons
I also noticed a lot of carbon build upon my valves any tricks to clean that up the head just needs clean up and valve seals
