Author Topic: Springs and Dampers for S2 Europa  (Read 2766 times)
Re: Springs and Dampers for S2 Europa
« Reply #15 on: Monday,March 24, 2025, 06:00:53 PM »
Wondering if the Scale front shocks having the offset top mount has any wear issues by putting a slight side load on the shaft as it compresses?
Offline kapps
« Reply #16 on: Thursday,March 27, 2025, 03:27:51 PM »
Installed the GAZ rear shocks today.  They seem fine.  I like that they are not flashy.   I was surprised how worn the AVO bushings were.  Of course shock oil leaking onto  the poly stuff is not ideal.
I was provided a shock dyno sheet and can upload that if there is interest.
Dean
Yep. Poly bushings and Avo oil do not go together well.
S2 0705R
« Reply #17 on: Friday,March 28, 2025, 06:49:12 AM »
Probably not much of a wear issue because I can't see how they'd even fit as depicted.  :confused:
If the shafts can be rotated, then maybe?
