Author Topic: Body bolts  (Read 1520 times)
Offline Jerryh
Body bolts
« on: Monday,March 31, 2014, 12:59:01 PM »
Hi
Can anyone please tell me the bolt sizes and thread for the Twin Cam body fixing bolts please
Any help most appreciated
Jerry
Re: Body bolts
« Reply #1 on: Monday,March 31, 2014, 01:38:24 PM »
To be honest I don't think they are listed in the parts manual, but a quick scan through the knowledgebase came up with this;
2 rear frame - 3/8"-24 x 1-1/4"
2 base of firewall - 3/8"-24 x 3/4"
2 seatbelts - 7/16"-20 x 1-3/4"
2 Lower dash mount - 3/8"-24 x 1-1/4"
2 Front Top of the spring/damper mount  - 3/8"-24 x 1-1/4"
All UNF threads ?
source of info - Yahoo list postings. It might be worth looking in the files area to see if anyone has made up a definitive "chassis change" list ?
Offline Jerryh
Re: Body bolts
« Reply #2 on: Monday,March 31, 2014, 02:16:06 PM »
Thanks Brian
I did have a quick scan earlier but couldn't find anything,  many thanks for the prompt reply.
Jerry
Re: Body bolts
« Reply #3 on: Monday,March 31, 2014, 02:36:21 PM »
Here is the page from the repair manual. You have to go to the parts book to decipher the bolt sizes. I've done these bolts and listed them below the illustration.
X = Hexhead
UF = U.N.F.
B = Bolt
06 = number of 16ths or 3/8"
24 = length in 16ths or 1 1/2"
So the rear bolts are 3/8" UNF 1 1/2 inches long
Fronts are 3/8" UNF 1 1/4" long
Dash bolts are 3/8" UNF 1" long
Fire wall bolts 1/4" UNF 3/4" long (except I don't think they are used on the Twin Cam.
« Last Edit: Monday,March 31, 2014, 02:49:57 PM by LotusJoe »
Re: Body bolts
« Reply #4 on: Monday,March 31, 2014, 03:29:54 PM »
I think Banks Europa has body fixing kits which may help
Offline Jerryh
Re: Body bolts
« Reply #5 on: Tuesday,April 01, 2014, 11:01:49 AM »
Many thanks for the replies, managed to get it all bolted down today, the threads in the top of the transmission tunnel were very stiff when I tried the bolts but a bit of working in and out and a spray of WD40 did the trick.
Jerry
