I have a nearly successful S2/TC adapter bush for the Hachille type door hinge conversion.
The ID came out about .020" small.
3D does not print a perfect circle, it is a just slightly faceted.
Close enough that a little sanding will save the first part.
I will tweak the geometry for the next one.
As long as the printer is warmed up, I am also printing hinge gaskets.
Well, I WAS printing gaskets.
One PITA about 3D is getting the part to remain adhered to the build plate.
Long thin parts, so of course they curled just enough to be ruined.
Another try.
