Author Topic: Cannot find a thread, Industrial plastic balls for door hinge repair?  (Read 7119 times)
Offline Hachille
Re: Cannot find a thread, Industrial plastic balls for door hinge repair?
« Reply #15 on: Wednesday,December 11, 2024, 10:55:22 AM »
I don't know what you asked them, of course.  But the part is very general-purpose and I'm not surprised if they don't know how to help you apply it to your Europa.  They could still answer you.  Maybe they're like the British suppliers though.  Most are kind of helpful if you're about to order.  Otherwise, forget it.
When I get to it and figure out how to get the door off, I'll have some questions for Hachille.  I don't really understand how he has them mounted.  I suppose I could figure something out, but would like to benefit from his experience.
Google translate was only so helpful though when it gave him "Be careful, you have to be empty or there are red arrows." !  I know all those words, but I sure don't know what that means!  :-)
Below is the page detailing the part, -12 being the specific one.
Hello
This means that the ball joint must be able to move up or down. The red arrows show that the space is available to move up or down.
When using a 26mm cone 2 drill bit, you get a tight fit with the igubal ball joint. It is possible to push it in and it will no longer slip. The igubal ball joint has a diameter of 26.1mm.
By using a new drill bit and a 17mm socket to turn it, it is the outside of the socket which is +-25mm that centers the drilling. The drill bit is between the two drillings.
I hope my translation is correct
« Reply #16 on: Wednesday,December 11, 2024, 12:05:34 PM »
Look at McMaster-Carr  1071K25  looks very similar if not the same.
« Reply #17 on: Wednesday,December 11, 2024, 01:58:19 PM »
Pic ….
« Reply #18 on: Wednesday,December 11, 2024, 02:58:47 PM »
There are more pictures from Hachille on page 67 of my build thread for TCST because I had questions too!
« Reply #19 on: Wednesday,December 11, 2024, 03:59:29 PM »
Ah, McMaster.
I failed when I looked there.
Local will be simpler.
« Reply #20 on: Wednesday,December 11, 2024, 04:14:49 PM »
Apparently I am really bad at search.
I cannot find pics of this on page 67 of your thread, or am I looking in the wrong place?
« Reply #21 on: Wednesday,December 11, 2024, 04:27:12 PM »
Richard,
I have mine set up to show newest post to oldest so it may be in reverse order  :confused: it is on page 7 in the oldest to newest chronology.
Sorry for any confusion  ::)
« Last Edit: Wednesday,December 11, 2024, 04:32:08 PM by TurboFource »
Offline Fotog
  • 72 Twin Cam
« Reply #22 on: Wednesday,December 11, 2024, 05:13:49 PM »
Igubal sells directly in the US, I see.  Their US base is in Rhode Island.
https://www.igus.com/product/igubal-KGLM
Vince
Offline Fotog
  • 72 Twin Cam
« Reply #23 on: Wednesday,December 11, 2024, 06:03:13 PM »
Richard:  here are the posts that T-fource is referring to:
https://www.lotuseuropa.org/LotusForum/index.php?topic=4034.msg44783#msg44783
-V
« Reply #24 on: Wednesday,December 11, 2024, 10:22:25 PM »
I made an effort to translate the text of the assembly drawing.
Some words did not translate well.
Montage porte ibre en hauteur Mounting the door ibre in height (ibre?)
Bleu : Porte Blue: Door
Noir : Coque Black: Hull
Rotule plastique Igubal Igubal plastic ball joint
En plastique technique Made of engineering plastic
Rondelle fine 8 End washers 8
Rondelle epaisse 8 Thick washer 8
Jeux de reglage Adjustment Sets
Montage port fixe en hauteur Fixed port mounting at height
Insere de coque inferieur Lower shell insert
Cale de position pour la hauteur de la porte Position wedge for door height
Adjustment serre  adjustment greenhouse
Cale de hauteur En plastique technicque  Height wedge Made of technical plastic
Now, is the other plastic component sold or something I need to make myself?
« Last Edit: Wednesday,December 11, 2024, 10:27:09 PM by Richard48Y »
Offline Nockenwelle
« Reply #25 on: Thursday,December 12, 2024, 02:55:39 AM »
'ibre' seems to be a victim of JPEG compression and should read 'libre' -> 'free or freely'. It means that the upper door mount is not restricting the vertical positioning of the door. The green part of the ball bearing is able to slide on the purple coloured insert.
« Reply #26 on: Thursday,December 12, 2024, 04:08:59 AM »
Hachille, what is the part sticking through the door and one is covered with the rubber cover?
Offline Hachille
« Reply #27 on: Thursday,December 12, 2024, 11:00:25 AM »
Montage porte ibre en hauteur Mounting the door ibre in height (ibre?)= Nockenwelle's translation is perfect
action=post;quote=73938;topic=6824.15#postmodify
Bleu : Porte Blue: Door = Yes
Noir : Coque Black: Hull = This is the bodywork. So the fixed part relative to the door.
En plastique technique Made of engineering plastic= It is a plastic that has good mechanical quality. PA6 for example
Rondelle fine 8 End washers 8 = example:M8 x 22 x 1.5
Rondelle epaisse 8 Thick washer 8 =example:M8 x 30x 5
Jeux de reglage Adjustment Sets = empty space to move the M8 screw
Montage port fixe en hauteur Fixed port mounting at height = the assembly of the part at the bottom of the door, fixes the height position of the door
Insere de coque inferieur Lower shell insert = It is the aluminum part "Bobins" which is in the fiberglass
Cale de position pour la hauteur de la porte Position wedge for door height = It is a plastic part (PA6 for example), which must be custom-made to obtain the correct height position of the door.
Adjustment serre  adjustment greenhouse = With a S1=Light door. There is no need to fix the ball joint in the door. This is the advantage of it being plastic which can have a tight fit. Probably the same for an S2
Cale de hauteur En plastique technicque  Height wedge Made of technical plastic = 11mm for my car. maybe 10 for yours. Et PA6
Now, is the other plastic component sold or something I need to make myself= Yes make myself?
Offline Hachille
« Reply #28 on: Thursday,December 12, 2024, 11:19:28 AM »
the aluminum part holds the rubber part. The rubber part must be cut so that the door when fully opened crushes the 2 rubbers at the same time.
« Reply #29 on: Thursday,December 12, 2024, 12:30:17 PM »
So they aren’t really part of the pivots?
