Author Topic: Rescued, Early S1  (Read 12609 times)
Rescued, Early S1
« on: Sunday,November 24, 2024, 05:09:29 PM »
  Rescued this S1 today, probably 20 years too late. No registry info.
   I don’t know how the PO’s removed the frame yet. It seems they are bolted from underneath but the fiberglass was not cut out at the T section. Swept out years of debris and will pressure wash tomorrow.  I’ll have to research how to open locked doors.
  Frame is a goner.  So what to do, seems to be salvage what I can and decide on what to place the body on.
« Last Edit: Sunday,November 24, 2024, 05:12:09 PM by dakazman »
Re: Rescued, Early S1
« Reply #1 on: Sunday,November 24, 2024, 06:20:42 PM »
Now THAT is project! Good luck!
Offline Fotog
  • 72 Twin Cam
« Reply #2 on: Sunday,November 24, 2024, 06:22:24 PM »
Looks like it could use a little compound and wax, but at least the engine looks good.
« Reply #3 on: Monday,November 25, 2024, 05:58:50 AM »
As others have pointed out elsewhere, that is not an S1 chassis.  Looks to be an S2 chassis from a 65.
If you can find a good S2 chassis, they can be modified to S1 spec.  That's what I did for mine.
« Reply #4 on: Monday,November 25, 2024, 05:24:42 PM »
  I didn’t think so either.  Frame contained an engine and gearbox that the owner wanted gone
Well after collecting everything he had the frame looks like this. I will try to find the sn so we can have a proper moment of silence.
   No tag on this gearbox and the engine is an 821-30.
  After pressure washing the body shows only minor damage. To my surprise it cleared up nicely
And I added a piece of her bling . While viewing some of earlier S1 I saw some had warts and the quarter glass windows.
  Tomorrow’s plan is to drill out the door catch screws from behind and open the locked doors. I tried to reach inside but moving the linkage didn’t help.
  How they got the frame out still eludes me. Probably in pieces.
« Last Edit: Monday,November 25, 2024, 05:26:59 PM by dakazman »
« Reply #5 on: Tuesday,November 26, 2024, 06:37:22 AM »
That chassis is also from an S2.
They removed the S1 chassis by cutting away the bulkhead between the passenger and engine compartments.  That is also where the seats fit so I hope you have the those panels.  I removed mine that way.  Worked fine but there is a lot of glassing to get it all back in.
« Reply #6 on: Tuesday,November 26, 2024, 05:57:42 PM »
  I picked up the group mainly for the engine/ gearbox.
I wasn’t expecting to keep the frame and it now is cut up in small pieces. I kept what I think can be salvaged off the frame.the S2 mod to S1 is off the table as is a spyder frame, as the company isn’t making them anymore. I’ll verify that asap.  If I’m to rebuild I’ll have to fabricate from scratch from the plans online.  Or some Frankenstein mod 🙀. I’ll concentrate on just doing repairs to the spider cracks , veil after sanding down and a good primer and sealer.
  I did not find anything that resembles a front bulkhead but have the console cover and the rear boot box, pictured earlier.
« Reply #7 on: Tuesday,November 26, 2024, 06:39:29 PM »
You could build a chassis like Roddymac did on his Europa 8)
« Reply #8 on: Tuesday,November 26, 2024, 08:35:42 PM »
What a find! You are doing Gods work!! S1s are the coolest welcome to the brotherhood :)
Offline berni29
« Reply #9 on: Tuesday,November 26, 2024, 11:58:08 PM »
Hi
You get a bravery award for sure. You clearly like a challenge that is actually a proper challenge. Wishing you the best of luck, and well done for attempting to bring her back to life!
All the best
Berni
Also have some +2's
Offline cazman
« Reply #10 on: Wednesday,November 27, 2024, 06:29:48 AM »
Could a the body be put on a Twin Cam frame? I would love to make a tribute Type 47.
1973 Europa TCS
Offline RoddyMac
« Reply #11 on: Wednesday,November 27, 2024, 07:16:47 AM »
If you have a large wad of cash burning a hole in your pocket, you could contact Kelvedon and see about getting a 47 chassis for it.  The downside would be having to buy all the rear suspension bits to make it work.
As for making one from scratch, with companies like Send Cut Send becoming more accessible, it might be an "easy" button for getting all the various pieces of sheet metal cut and bent.  Unfortunately, I dont think it would be all that cheap unless you were to get a few chassis' worth of pieces cut.
Offline My S1
« Reply #12 on: Wednesday,November 27, 2024, 10:20:49 AM »
Dakazman,
thank you for your efforts to resurrect that S1.  You have quite a challenge to take on but look on the bright side, you can do whatever you want with it.  Nobody will fault you for straying from perfection or originality. To get it back to original S1 spec, as you know, would be a #$%@ of a job and allot of cash and time spent searching for parts around the world.  It will be worth the hard work.  Good luck to you and thanks again.
Offline Nockenwelle
« Reply #13 on: Wednesday,November 27, 2024, 12:54:10 PM »
Very interesting find and a big project for sure. Can you confirm that the VIN is 460148 or is it 460140? The picture is not 100% clear to me.
Concerning a new chassis: Richard Winter of Europa Engineering is still able to produce a chassis pretty close to S1 spec. Some details like the foot well cover around the front axle pickup points still needs to be added. My brother just bought a new chassis from him and finished it. If you are interested please contact me and I'll pass you more details.
« Reply #14 on: Wednesday,November 27, 2024, 05:54:17 PM »
  Thank you for all for your support with this project.
  I was able to get to it today for my planned job of opening doors .  As I  was cutting off the door plates from behind the door jamb looking for the build plate as with the S2 . Well no such plate , then I remembered a thread on SN’ being formed into to body, we’ll long behold there it was , just inboard of the rear boot hinge. See pic . NOT Agreeing with the front boot plate 0148. Paint color or gearbox not stamped on the front boot plate .
   Then I exceeded my goal of opening doors to removing them completely and laughed when I opened them to see the,”do not lean” stencil on the jamb. Then surprised they moved and stayed in plane I opened and closed them until they fell off in my hand.  Found no water drains in doors either.
  The body had been painted prior, bearing witness to a coat of gelcoat just atop the bare fiberglass.
  A 47 project sound great powered by my 843 cross flow.
