Author Topic: Rescued, Early S1  (Read 12916 times)
Offline My S1
Re: Rescued, Early S1
« Reply #45 on: Wednesday,January 01, 2025, 04:19:28 PM »
David,
in an earlier post on this thread you mentioned the eighteen day discrepancy between your body tag and your vehicle/chassis tag.  This aroused my curiosity so I unearthed my body tag. I  have a six day (body post chassis & VIN) time spread.  My S1 is 46/0202 but my body is 0208.  Obviously they stacked up the bodies before assembly and final tags.  My car was invoiced to Germany on 10 October 1967.
« Reply #46 on: Friday,January 03, 2025, 05:58:14 AM »
  Thanks S1,
  That should clear up the body tag as the serial number controversy or stir up more.
   I finally made a second attempt to split the motor from the gearbox. I separated it enough to remove the pressure plate bolts and I was able to break the clutch plate off .
Off with the oil pan to seek more answers …This time was not in vain but… it still needs more soaking in a penetrant. 🥴
 At least it’s in smaller pieces so I can move them around.
  At least the gearbox turns and gets all 5 gates.
Offline My S1
« Reply #47 on: Friday,January 03, 2025, 08:57:44 AM »
You are a brave man!  Most guys would use that as a boat anchor.  I'm anxious to see how you breath life back into it.  Good luck my friend.
« Reply #48 on: Saturday,January 04, 2025, 07:02:18 AM »
  S1, Looks like the boat anchor scenario was correct.see gapping hole in block after cleaning. The only things I may salvage might be the rods, cam, crank and some miscellaneous pieces.  Gearbox good , save for a little chip out of the bellhousing. Head is still fighting some lifters but its going to the my press soon.
  Now for the other engine.
 I just like to know the status of usable parts and throw out the rest. No sense storing and moving junk.
« Reply #49 on: Saturday,January 04, 2025, 09:35:09 AM »
Yikes!
« Reply #50 on: Saturday,January 04, 2025, 01:46:22 PM »
A clean scrap block can be surprisingly useful.
I have one I am using to take accurate measurements from to make a crank scraper.
I may also use it as a dummy to let my chassis roll before putting in the good engine.
« Reply #51 on: Saturday,January 04, 2025, 06:09:37 PM »
 Well this is the last will see of 1171. 😥
  Reduced to a small pile of parts, I need to press out the wrist pins, pistons shot saved the oil filter threaded adapter and all oil gallery plugs. Maybe I’ll have some fun and drive my lotus to the scrap yard with all my aluminum and get weight in🤣 killing two birds in one shot.
  Besides putting away Christmas it’s been a busy day.
« Reply #52 on: Sunday,January 19, 2025, 04:49:08 PM »
  I found some time to remove the inner door lock items and order a sheet of laminate to make the panels for the interior dash.
  Are any items available for purchase for the doors. I just want to get the body completed and will purchase some SS door hinges but I can’t find the lock assembly or door catch items.
  Then what holes in this center panel are not original?
 I did did this pic of what may be original. Last pic
« Last Edit: Sunday,January 19, 2025, 05:17:11 PM by dakazman »
Offline My S1
« Reply #53 on: Monday,January 20, 2025, 09:30:24 AM »
David,  here is one of my previous posts regarding the IP panels;  S1 I.P Panels
Offline RoddyMac
« Reply #54 on: Monday,January 20, 2025, 10:06:57 AM »
Door hardware might be easier to find in France rather than North America.  I quick search on Ebay.fr for "Renault R16 Porte"  brought up a couple latches, but they appear to lack the locking mechanism:  https://www.ebay.fr/sch/i.html?_ssn=whytedeamon_2&store_name=vintageagestore&_oac=1&_trksid=p4429486.m3561.l161211
If it's not at the top of the list, search for "Serrure de porte arrière gauche neuve d'époque pour Renault 16 R16 7701450152"
My car has one with a lock and the other without, but I don't have a key for the one with a lock.  I'm not too concerned as I rarely leave it unattended.
« Reply #55 on: Wednesday,January 22, 2025, 05:50:24 AM »
  S1,
  I have the material so I just jumped in to see how this laminated material forms. I’m just going to cut the basic shape and maybe the gauge holes. Posted the front, side and back for clarity.
  Roddy,
  Thanks for the info. I thought the eBay prices were high until I went to Renault16shop  where it looks like they compare with what I have . 212.00 I believe euro’s is out of the question plus shipping. I’ll continue to search as you instructed.
Offline SwiftDB4
« Reply #56 on: Wednesday,January 22, 2025, 08:13:35 AM »
The holes you have on the dash are original. They match my S1b except I have a wood dash.
Offline Hachille
« Reply #57 on: Wednesday,January 22, 2025, 10:35:21 AM »
  S1,
  Roddy,
If you need, I have DXF files to do the laser cutting. You just need to add the ashtray.
« Reply #58 on: Wednesday,January 22, 2025, 06:04:37 PM »
 Hachille, thanks
I sent you a PM .
« Reply #59 on: Saturday,February 15, 2025, 05:24:47 PM »
  Still waiting on the DMV to verify my antique car application. I’m starting to get worried.
 I’ll give it another week.
   I finished stripping the entire body down of everything that is no fiberglass or held on by fasteners. I did repairs on the bonnet and sanding it down. I’ll remove the engine cover this week and work on the minor defects in the glass.
