Author Topic: Dangerous to life split pins  (Read 3169 times)
Offline Sparkrite
« on: Sunday,November 17, 2024, 10:35:05 AM »
I decided to remove the gearbox output shaft seals on my tcs in order to try and eliminate the small leak from the seal nut threads. In order to do this I drifted out the split pins that hold the half shaft/axle. Upon inspection they were cracked (as can be seen in the photo). This crack would only worsen until the wheel/axle would come adrift from the output shafts with dire consequences. These pins were new about 1000 miles ago,and I had the smaller one inside the larger pin. The shaft was properly shimmed so the only thing I can think of is the poor quality of the pins or maybe I should have used the spiral pins instead.
Re: Dangerous to life split pins
« Reply #1 on: Sunday,November 17, 2024, 11:41:57 AM »
The photo doesn't show it but was the smaller pin also cracked?
« Reply #2 on: Sunday,November 17, 2024, 11:45:41 AM »
They crack because they are not shimmed tight enough which allows flex, causing the cracking and breakages.  It is not a big deal as they will run just fine without any pins installed as long as you don't jack the car up our Keanu Reeves your car off hill crests.
Offline Sparkrite
« Reply #3 on: Sunday,November 17, 2024, 12:26:21 PM »
One of the inner pins has one crack where's the outer pins had two cracks each.
The way I see it is the correct shims only work in compression,when the road wheel is being pulled outwards there are stresses on the pins,hence the cracks.
« Reply #4 on: Sunday,November 17, 2024, 01:07:11 PM »
It's good to be reminded that proper shimming of the inner u-joint is important.
The TC and TCS use spirol pins which are rolled spring steel. The hardness (and therefore brittleness) of spring steel and the thin section of that steel in the spirol pins encourages cracking. I would expect that the u-joint being loose also encourages cracking because shock loading would be more likely to cause a crack than simple shear caused by tension or compression forces on the u-joint.
Offline 2766R
« Reply #5 on: Sunday,November 17, 2024, 01:31:22 PM »
I recently removed the the inner half-shafts to replace leaking seals and found a failed spiral pin.  I know the shimming was correct but still the failure.  I ordered new spiral pins from Grainger.  Comes in a package of 10 so should last until I'm no longer able drive my TCS!  O:-)
https://www.grainger.com/product/Spring-Pin-41KN49
BTW, no more leaks from the seals as of yet!  :trophy:
Gerry
Offline kram350kram
« Reply #6 on: Sunday,November 17, 2024, 06:58:56 PM »
Wonder if stainless steel pins might be worth a try? They area bit more ductile.
Offline 314159td
    • Project Portfolio
« Reply #7 on: Sunday,November 17, 2024, 07:50:17 PM »
I'm pretty sure the right move here is jumping directly to a hardened shoulder bolt. May need to grind a small taper on the end to hammer it in nicely, and likely will require match drilling to get everything just perfect without slop. I do this with pretty much every cross pin in anything, except the ones designed to fail and protect other components.
I've thought through a few ways of doing this, will post with part numbers if/when I implement it.
« Reply #8 on: Monday,November 18, 2024, 10:38:13 AM »
If we sit down behind the rear left wheel and look at the suspension, it should be observed that the load path travels from the tyre patch, up to the wheel hub and then along the stub axle, half-shaft and then to the gearbox side bearings.
This load is accepted by the spring but constrained by the lower link because it connects to the upright about 6 inches or so below the axle.
In a right hand cornering manoeuvre, the additional load is transferred to the spring which acts, in turn, on that lower pivot point of the upright.
Therefor, the axle assembly is always* in compression and the lower link is always in tension.
*unless performing the antics JB outlined.
At least I think that's right and someone will unceremoniously beat me up if it isn't.  ;D
« Reply #9 on: Monday,November 18, 2024, 05:47:24 PM »
"Therefore, the axle assembly is always in compression and the lower link is always in tension."
100% correct.  It is not an issue.
Offline Sparkrite
« Reply #10 on: Tuesday,November 19, 2024, 01:26:39 AM »
I must be wrong as I see it different to the experts.
But if you're viewing the car as Gavin described, then on hard right cornering the left tire contact patch moves inwards as the centrifugal force is pushing the car/wheel outwards to the left.This means that there is compression on the lower link and tension on the half shaft surely?.
On a simplified view, if I just grab the lower tire and push it inwards towards the gearbox,then the lower link is compressed and axle tensioned.
« Reply #11 on: Tuesday,November 19, 2024, 04:35:56 AM »
G'day Sparky,
Think of it this way:
Presumably it's accepted that the load path dictated by gravity travels as first laid out - upwards from the tyre etc.
The spring, in reaction, resists that load but the important part to note is that the spring is connected below the stub axle and, as such, follows a different path to the gravity induced load.
The spring is actually trying to rotate the stub axle clockwise with the U-joint acting as the pivot in a kinda bellcrank effect.
This is the case even when the car is static in the garage.
This could be tested.
Jack up the car to relieve suspension loads. Place a dolly or garage skate under the wheel. Disconnect the lower link from the upright and slowly lower the car till the tyre starts to contact the dolly.
Which way does the wheel move?
So, yes, in a right hand corner, the car will distort the tyre contact patch inwards but that's because the spring is effectively 'pushing' the lower pivot point of the upright outwards. The centrifugal force induces weight transfer and is translated as increased spring force, not a separate one.
If the lower pivot point of the spring was at axle height, the bellcrank effect would be negated.
In a wilder moment it occurred to me one could jury-rig some lower links from wire rope and still be OK, but don't try this at home.  ;)
« Reply #12 on: Tuesday,November 19, 2024, 05:30:35 AM »
How much does the gyroscopic effect of the wheel have on all this?
When a wheel and tyre are revolving at say 40 mph, and the wheel is affected by turning a long right turn, what gyro effect will that wheel have  on the suspension.
Asking for a friend .....
« Reply #13 on: Tuesday,November 19, 2024, 06:51:17 AM »
It's pretty simple really, people have driven their Europas hard with no pins in place and no issues.  However, if you jack up the car with the rear wheels hanging, the half-shaft may slide off and would be a right pain to get back on.  By all means use the pins but just don't worry about them cracking.
Offline cazman
« Reply #14 on: Tuesday,November 19, 2024, 09:26:16 AM »
I always thought that the pin was important so that the drive shaft does not slam repeatedly into the output shaft/bearing of the trans.
1973 Europa TCS
