Author Topic: Distributor rebuild  (Read 835 times)
Offline califkid_66
Distributor rebuild
« on: Friday,November 08, 2024, 12:37:25 PM »
Started taking my distributor apart cause I noticed the shaft was loose and as I mentioned before it has bushings also noticed clips holding the weights were worn out and not holding them in the right position Im probably not going to be using it but I just like fixing stuff !
 I’m not decided what the next step for the Europa is rebuild the wedge or take a chance with the crossflow just fixing things as I go along
Re: Distributor rebuild
« Reply #1 on: Sunday,November 10, 2024, 07:15:34 AM »
We used to often rebush, repair, and recalibrate distributors.  I still have a distributor advance machine in my basement.  I now run 123igntion distributors in both my Lotuses.  A lot less work and programming the advance curves is super easy.
Offline califkid_66
« Reply #2 on: Wednesday,November 13, 2024, 04:23:50 PM »
The 123 was the plan I’m working on the Europa this winter I’m not sure yet want I want to do but I’m taking out engine and transmission as you mentioned the distributor with the adapter is not available so since I have the wedge distributor apart and another for the crossflow i was thinking of using the measurements of these two to fabricate an adapter like the one you have so that when I get the 123 I can use it on wedge or crossflow
