Author Topic: Lower steering column.  (Read 2158 times)
Re: Lower steering column.
« Reply #15 on: Wednesday,September 04, 2024, 11:27:38 PM »
Wow, good post, I'd never have expected that amount of difference.  I guess the next question is if the S1 is the same as the S2 & later variants ?
Offline Dilkris
« Reply #16 on: Thursday,September 05, 2024, 12:13:42 AM »
Really helpful photo - so we can now assume that the Europa part is very much a one off correct?
« Reply #17 on: Thursday,September 05, 2024, 03:10:25 AM »
Hmm, I thought I knew this one as I'd expected it to be the same as the Elan,  but now I don't. It's odd, the part numbers in the book are different and I wonder if there's anything about the early cars without steering lock and the later ones with a lock.  I can't see how this would affect the lower column but the numbers are slightly different even if the TC does have the type 46 lineage.
S2
046H6005 Lower Column
TC
X046H6003Z  Lower column
« Reply #18 on: Thursday,September 05, 2024, 08:27:42 AM »
The Introduction to the parts manuals describes the part number scheme but I’m not sure how to read those part numbers. I couldn’t find an explanation for the ‘X’ in the TC part number. The ‘46’ in both numbers seems to refer to the car on which that part originally found implying they must be the same part but the S2 part is 6005 while the TC part is 6003. Why would the “suffix” change if it was the same part? I couldn’t find an explanation for the ‘Z’ in the TC part number.
« Reply #19 on: Thursday,September 05, 2024, 08:44:52 AM »
I'm just as confused but logically if they have different numbers there's probably some difference  even if it's minor.
I am surprised that Lotus didn't use an off the shelf part for something like that. Maybe as Roddy posted about the different Triumph columns they used the TR6 (4a for the time ?) part on the S1 and then maybe another Triumph part later when the cabin/seating position was redesigned.
It's Lotus. Who knows what they did back then.....
« Reply #20 on: Thursday,September 05, 2024, 09:07:10 AM »
Ditto the steering rack.
I have ordered a new one from Banks/Lotus Surprise, 7 weeks ago......
Offline 314159td
    • Project Portfolio
« Reply #21 on: Thursday,September 05, 2024, 04:18:45 PM »
Lots of parts that we think of as "Triumph parts" or etc aren't quite that, they're just sourcing from the same supplier. Europa drum backing plates are basically the same as the GT6, but some holes are in different spots. The iconic uprights, steering racks with extensions, etc.
Probably the same idea with this part, it's all the same features and is made with the same tooling, but it doesn't need to be exactly the same. The made a few thousand of these cars not like 10, so some suppliers were willing to negotiate for simple variations, and I'm sure it cost Lotus more than Triumph or whoever.
« Reply #22 on: Friday,September 06, 2024, 09:41:50 AM »
Would it be one was supplied with the flexible/rubber universal and the later one supplied with the metal universal or are those parts called out separately (I'm not at my stack of parts manuals).
« Reply #23 on: Friday,September 06, 2024, 10:42:47 PM »
I don't know Bryan although that makes sense and could well be the reasoning.
From my parts list copy the S1/S2 & later TC/TCS appear to have the same "046" heritage part number based on where it was first used but the remaining numbers are different. I do know that you can swap out the rubber flexible joint for a metal one as I did that on the Elan years ago and the splines/column accommodated the mod but I didn't measure the overall length of the metal UJ or OEM rubber one.
I must admit I'm far more cynical of 1960/70's Lotus than most and I can easily believe that they used whatever they had to hand to get cars down the line. I can hear the conversation now...
"Colin - we can't get Herald columns, they're out of stock"
"what can we get ?"
"TR4"
"does it fit ?"
"just about"
"get 'em in and get the car sold".
They were still doing that in 1999 when I bought a new Elise. That came without the decals showing the switch function on some of the Peugot 105 switches.
"Lotus have a supply problem sir, we've had a couple of cars like that this month. We'll fix it at the first service, but that one on the left is your side lights, the next is the main lights"
Peugot switches and they hadn't got the right ones to build cars...... (they did fix it though)
« Reply #24 on: Friday,September 06, 2024, 11:51:21 PM »
"Colin, we have run out of credit with those suppliers, and they won't send us any more until the account arrears are paid."
"Can we get credit anywhere else for something similar that we can make to work?"
"I will hunt around and see what we can get."
« Reply #25 on: Saturday,September 07, 2024, 12:02:20 AM »
I'm too much of a sensitive soul to suggest anything like that.....
« Reply #26 on: Saturday,September 07, 2024, 07:07:50 AM »
I think you both give reasonable scenarios but that sort of thing must have actually happened at Avanti (started as a Studebaker model). They used whatever parts they could find from whatever sources would sell to them. It is so bad that collectors have a hard time proving their car is unmodified. It must have been tough for the designers who had to design the various mounts, brackets, etc.!
« Reply #27 on: Saturday,September 07, 2024, 07:33:22 AM »
https://www.youtube.com/watch?v=uErKI0zWgjg
« Reply #28 on: Saturday,September 07, 2024, 07:43:18 AM »
Very funny song!! Even funnier that a Brit would point me to it!!  :FUNNY:
Offline RoddyMac
« Reply #29 on: Tuesday,September 10, 2024, 06:58:28 AM »
My guess is the lower column might have changed slightly where the pinch bolt goes through.  One of the columns I have has a groove all the way around, the other has a short groove to keep the UJ/Flex joint it a certain alignment.  I'll pull the Elan column down from the shelf this next weekend to see what it has.
