Author Topic: New Project  (Read 12881 times)
Re: New Project
« Reply #30 on: Saturday,August 24, 2024, 12:37:14 AM »
 :I-agree:   :FUNNY:
Re: New Project
« Reply #31 on: Tuesday,August 27, 2024, 03:21:17 PM »
My project, TCST, has had many tests, welcome to Europa world!
  Ditto, I guess it's just a builders choice in what is and what can be... :FUNNY:
Offline DAllen
Re: New Project
« Reply #32 on: Wednesday,August 28, 2024, 07:35:58 AM »
Stromberg to Webber conversion done by Northshore Sportscars in Libertyville Illinois.  Yeah, this setup looks serious.  I expect I'd go the Mikuni route if it became anything other than garage art.
Re: New Project
« Reply #33 on: Wednesday,August 28, 2024, 09:03:16 AM »
What main jets, air correctors, emulsion tubes and choke size are you using?
Offline DAllen
Re: New Project
« Reply #34 on: Monday,April 07, 2025, 04:32:12 AM »
I took the engine/transmission to Yves Boode @ Vintage Sports Car in Woodstock Illinois for disassembly and rebuild.  Yves is going to dial in another 50hp or so.  Next step is to lift the body off.  There are just a few more items to disconnect.  Can the body be supported with planks running under doors, wheel well-to-wheel well?  That appears to be the easiest way, but as that area carries no load to begin with, I am considering alternatives.
I can't see a complete "restoration" on this car, but more of a "rebuild" sort of undertaking.  No need to throw good money after bad; I crossed that line some time ago!  Then again, my objectives are subject to change as I proceed.
This project is taking much longer than what I originally envisioned.  I expect that is par for the course.  It is the journey, not the destination?
Online Kendo
Re: New Project
« Reply #35 on: Monday,April 07, 2025, 11:49:51 AM »
If you have a TCS, the official jacking points are just behind the front wheel arches and just in front of the rear wheel arches. So boards under the body at those points would work fine. This might be true for other models. But I know the TCS.
Offline DAllen
Re: New Project
« Reply #36 on: Monday,April 07, 2025, 12:58:01 PM »
Thanks, Kendo.  Yes, TCS.
