Author Topic: CAR ELECTRICIANS ADVICE WANTED  (Read 1964 times)
Re: CAR ELECTRICIANS ADVICE WANTED
« Reply #15 on: Tuesday,August 06, 2024, 07:11:37 AM »
So, if this is an added kit, might it have been installed incorrectly?
Offline HoraceM22
« Reply #16 on: Wednesday,August 07, 2024, 03:50:29 AM »
Although I was told that there should be a switch on my dash, I think that that info was given me by a guy looking at a US version, as per the link above. I've seen several UK cars here
https://www.uksportscars.com/view/lotus-europa-twin-cam-special-5-speed-1973-stunning-jps-black-with-gold-stripes/
The dash on this, and several others, are nothing like the US dash i.e no hazard switch as standard. As someone has pointed out that this type of switch was an aftermarket fitment to those who felt the need.
Picture of the switch are posted a few pages above.
I've tried a new Lucas 2 pin relay, and I did wonder if my original has gone pop and the new one is not the same spec, and I should try and locate a new-old-stock relay?
As I'm getting power to the light bulb wires at all four corners and continuity of the earth at all four corners I feel that it can only be the relay.
HoraceM22
« Reply #17 on: Wednesday,August 07, 2024, 07:50:41 AM »
A Tridon HD12 is a good 2 terminal flasher and readily available.
If you are running LED bulbs, you will need a special flasher,
« Reply #18 on: Wednesday,August 07, 2024, 12:34:01 PM »
I replaced the original 3 pin relay with one that works with LED's and emits a high pitched squeak when indicating. I've also bought an aftermarket hazard switch (that they use on tractors!) and another hazard relay that I have yet to fit. I'll work out the wiring when I do this.  STILL need to sort my clutch out first.....
« Reply #20 on: Wednesday,August 14, 2024, 02:28:13 PM »
[/quote
   Silver What's going on with your clutch? PM me.
« Reply #21 on: Wednesday,August 14, 2024, 03:49:53 PM »
[/quote
Slips once car has warmed up and is being driven more vigorously in higher gears.  It could be engine/gearbox mounts allowing too much movement as cable outer is still mounted to chassis. I have the mounts and the engine mounted bracket so they will be my starting point. Mainly I need to make time (and garage space because that is rammed at the moment). Life is giving me other priorities at the moment.
« Reply #22 on: Wednesday,August 14, 2024, 05:30:27 PM »
 Silver , I got it !
  Priority’s take  job 1 .
Just relax and take your time .
