Author Topic: Want to buy 123 ignition  (Read 487 times)
Offline califkid_66
« on: Saturday,July 06, 2024, 04:43:15 PM »
I have a 821 Renault wedge the bushing in my distributor are totally worn out
I want to buy a 123 ignition the basic one I just want the same ignition curve that the Europa came with don’t need programable I saw one that as a couple of curve’s programmed in it by turning a little thing on the side
Does someone have a link with the exact model I need cause when you write for r16 it gives all kinds of letters after I just want to make sure I order the right one
I’m located in eastern Canada
Thanks !
Re: Want to buy 123 ignition
« Reply #1 on: Saturday,July 06, 2024, 07:45:36 PM »
Just rebush what you have.  It has the right curve already.
« Last Edit: Sunday,July 07, 2024, 04:53:36 AM by jbcollier »
Offline califkid_66
« Reply #2 on: Saturday,July 06, 2024, 08:29:13 PM »
You’re right it’s just I was a bit discouraged it was going so well but it’s ok another challenge I have to find some bushings now I’m not sure if my problem was the coil or the worn out bushings but both will be fixed
Thanks again !
« Last Edit: Saturday,July 06, 2024, 09:06:38 PM by califkid_66 »
Offline cazman
« Reply #3 on: Sunday,July 07, 2024, 12:47:58 AM »
1973 Europa TCS
« Reply #4 on: Sunday,July 07, 2024, 04:54:18 AM »
That's the spirit.  I never take life personally.
