Author Topic: Hood/bonnet latch seal  (Read 3980 times)
Re: Hood/bonnet latch seal
« Reply #15 on: Monday,July 08, 2024, 02:59:44 PM »
  LOL.,
   On the Bonnet seal, I cut a block of aluminum and drilled two holes and a notch, used a simple gasket and the water cannot go thru the block . Get rid of just the interior plate.
Just say'in.
« Reply #16 on: Tuesday,July 09, 2024, 03:58:56 AM »
An enclosed box would be ideal but I don't have access to the back side. A Vintage Air AC/heater takes up the space. I am sliding every thing through from the front. I ditched the foam and used a silicone strip from a stick on door seal. I'm sealing up the pedals and steering shaft better now with neoprene instead of soft foam. Only the column left to do. Back plate has foam to seal against the FRP, front plate sandwiches a 1/16" thick neoprene washer. It makes adjusting the washer easy. I ordered some Thinsulate to add between the carpet and felt on backbone area and thicker foam for the foot wells. A 15 minute drive is nice but around 30 minutes the heat starts getting through the felt and thinner foam.
https://www.voguefabricsstore.com/3m-thinsulate-fabric-thermal-lining-cs150.html
« Reply #17 on: Tuesday,July 09, 2024, 08:28:07 AM »
Pretty nice. As I remember when I was building my car, there was a seal similar to that already on the steering column. I'll have to check my car and see what seals around the M/C push rod.
One of the leaks in my car is under the elbow pad. I remember when my car was new, there was a piece of foam rubber that filled that area. I've lost it but I'll be looking for a similar piece. You might consider something similar.
Offline kram350kram
« Reply #18 on: Wednesday,July 10, 2024, 06:45:18 AM »
Think I have what is an original hood latch seal , a thick rubber elongated boot with a chromed or polished stainless steel surround. Can post pictures if interested. I cannot use it as the hood rubs on it.
« Reply #19 on: Wednesday,July 10, 2024, 12:51:50 PM »
The rubber boot should mount from inside the car. There should also be steel surround like the chrome one that acts as the nut plate. The chrome goes on the outside. (IF I remember correctly. I drew an exploded view of it. But it's at home and I'm not.)
« Reply #20 on: Wednesday,July 10, 2024, 04:01:35 PM »
I can slide the nut plate in from the front with a longer screw to get it in with out fear of dropping it but I have zero access from inside the car.
I just finished the steering shaft seal. I took better pics of the pieces. I'll start a new thread for it.
« Reply #21 on: Tuesday,November 12, 2024, 07:13:33 PM »
Pic of seal ….
Offline Fotog
  • 72 Twin Cam
« Reply #22 on: Wednesday,November 13, 2024, 09:36:07 AM »
Tell us more.  What are we seeing there?
I realize that it's a view from under the dashboard.  But... did you get a proper seal from somewhere?  It looks like there's light shining through the slot for the locking part (whatever a locksmith would call it).
« Reply #23 on: Wednesday,November 13, 2024, 10:32:17 AM »
I think the apparent light is a glint off of the shiny leading edge of the rubber seal.
« Reply #24 on: Wednesday,November 13, 2024, 11:58:08 AM »
That is glare … amazingly the original part is still good!
Offline Elanman39
« Reply #25 on: Sunday,November 24, 2024, 08:54:00 AM »
The entire latch was missing from the S2 I've just finished.  I just made up a stainless trim piece for the outside with two countersunk bolt holes and a central slot for the lock tongue to go in with the slot at a slight angle to allow the tongue to pull the front cover down slightly.  To seal it I cut a short length of 3/4" box section, cut a hole on one side bigger than the slot in the stainless trim and put two rivnuts in to align with the countersunk holes in the trim.  I squirted some polyurethanse window sealant up each end of the tube to seal the box and put the tube inside the car, just above the wiper rack.  Oversizing the holes in the fibreglass makes the whole shebang adjustable to get a nice bonnet fit.  No-ones ever gonna se it so I wasnt too worried about originality  ;)
