Author Topic: Renault engine misfires  (Read 5415 times)
Offline califkid_66
Re: Renault engine misfires
« Reply #15 on: Wednesday,July 03, 2024, 09:57:06 AM »
Ok thanks I will
I want to put the crossflow in it but I have to many projects for now
I’m gonna run it like this for this summer
« Reply #16 on: Wednesday,July 03, 2024, 12:28:38 PM »
If you can figure out how long it takes for that plug to foul, you can just swap them about in half that time and you'll go a long ways.
Offline califkid_66
« Reply #17 on: Wednesday,July 03, 2024, 05:56:19 PM »
I’ll just remove it once in a while to check
I really like that engine it’s got lots of pep
and I checked I do about 32 mpg
Offline califkid_66
« Reply #18 on: Thursday,July 04, 2024, 12:08:14 PM »
Well it didn’t last very long went for a ride on the way back loss of power overheating couldn’t make it up a hill car died at first I thought water pump belt but no now I’m sitting in the Europa on the side of the road waiting for it to cool down
I think maybe something that did not help is I usually put a special blend of oil not sure if it’s
20 w 50 or 20w 40
I got 10w30 in it and it’s really hot today and I’m not sure my fan turned on
« Reply #19 on: Thursday,July 04, 2024, 12:25:35 PM »
Oh no!
Hate it when things go awry.  As long as the oil is moderately close to full, it wouldn't cause overheating.
« Reply #20 on: Thursday,July 04, 2024, 12:57:47 PM »
 :I-agree: It doesn't appear to me that oil is your problem. Maybe your thermostat stuck closed. Were you getting misfires again? Could there be a water leak?
Offline califkid_66
« Reply #21 on: Thursday,July 04, 2024, 01:59:02 PM »
I let it cool down a bit checked the coolant level was ok oil level is ok removed the cylinder 1 plug was a but sooty and dry
I have a ignition spark tester I tried on two cylinders I got spark but the spark was orange if I remember yesterday when I checked the spark in the tester it was white
It did start but barely idles and dies
« Reply #22 on: Thursday,July 04, 2024, 03:48:24 PM »
Heat related?  Condenser? (If you're still rocking points).
Offline califkid_66
« Reply #23 on: Thursday,July 04, 2024, 04:19:05 PM »
I have electronic ignition I ordered a distributor cap rotor and spark plug wires was supposed to arrive today but it’s going to be Monday I’m thinking could be coil but I have two and the numbers were the same
Offline califkid_66
« Reply #24 on: Friday,July 05, 2024, 04:46:47 PM »
I suspect my ignition coil is bad I have ne rotor distributor cap and spark plug wires
What kind of coil can I put can I buy one at Napa that would work I know absolutely nothing about coils but I read when they go bad they get weaker and I think this is my problem right now
So I’m looking to find one i can buy at an auto parts online takes a couple of days
« Reply #25 on: Friday,July 05, 2024, 04:55:00 PM »
Pertronix requires a 3 ohm coil. Your electronic ignition, if it's from a different manufacturer may require something else.
« Reply #26 on: Friday,July 05, 2024, 05:14:56 PM »
Blue Streak UC12X
NAPA Echlin  UNI IC1600
PerTronix 40611 Flame-Thrower
Bosch "blue" coil
Offline califkid_66
« Reply #27 on: Friday,July 05, 2024, 06:35:13 PM »
I have petronix
Thanks for the list of coils
I recieved all my part but I’m gonna
Install the new coil before trying to start it
Thanks again
Offline califkid_66
« Reply #28 on: Saturday,July 06, 2024, 05:31:41 AM »
Just tested the coil in the Europa and a spare , spare had the primary at 3.3 and secondary OL
I have 3.4 primary and secondary OL  on the Europa
Does that mean they are both bad or am I doing something wrong
Thanks again!
Offline califkid_66
« Reply #29 on: Saturday,July 06, 2024, 06:46:01 AM »
Uni ic1600  says use with external resistors
The coil I have says use without external resistors I tested uni ic1600
and had 1.1 primary and OL secondary
If I install the Uni ic1600 do I need to install a resistor
