Author Topic: Water in Fuel Tanks  (Read 5107 times)
Water in Fuel Tanks
« on: Saturday,May 18, 2024, 10:31:04 AM »
Has anyone else experienced water in the fuel tanks?
The water sinks to the bottom, so not much in the tanks will be sucked into the fuel pump and stop the engine from running, and it will spread into both tanks if only 1 is leaking.
I have checked both tank tops, and neither is leaking. There was about 2 pints in the tanks after the car was standing for about 9 months.
The filler caps are tight and the rubber connectors to the tanks are both new.
Is it just condensation in a damp climate?
Re: Water in Fuel Tanks
« Reply #1 on: Saturday,May 18, 2024, 10:44:15 AM »
That is a lot of condensation in nine months. How would the damp air get in the tank? Does it have vents open to the air? (No filters on them?) Could the water have been there nine months ago? Contaminated gas? I’m in arid California, so little recent experience with humid environments.
« Reply #2 on: Saturday,May 18, 2024, 11:49:12 AM »
That is a lot of condensation in nine months. How would the damp air get in the tank? That is exactly what I cannot understand.
Does it have vents open to the air? The tube to the long filter is not there and like most cars, that long filter side to side went years ago
Could the water have been there nine months ago? No the tanks were fitted completely dry.
Contaminated gas? No, 20 litres of super unleaded fuel was poured in from a jerry can, and carefully checked before it went in.
In the UK, we have had the wettest 18 months on record.
Online Grumblebuns
« Reply #3 on: Sunday,May 19, 2024, 08:13:27 AM »
Isn't there a overflow vent in the filler neck just below the grommet? If its open to atmosphere, the constant change in temperature over time will cause the tanks to "breathe". Is that enough time to cause all of that condensation you are experiencing?
« Reply #4 on: Sunday,May 19, 2024, 08:16:34 AM »
That’s the vent I was thinking about. I imagine it would depend on how full the tanks were, how much air volume could change with each “breath”. Another thought, are there gas formulations that like to absorb moisture from the air?
Offline SwiftDB4
« Reply #5 on: Sunday,May 19, 2024, 08:26:53 AM »
Alcohols like ethanol absorb more water than straight gasoline.
Online Grumblebuns
« Reply #6 on: Sunday,May 19, 2024, 09:17:47 AM »
I don't know the ethanol percentage in the UK. Do they even use ethanol over there?
« Reply #7 on: Sunday,May 19, 2024, 09:58:03 AM »
I have to use Super Unleaded, rather than normal Unleaded, which has a larger alcohol content. E5 petrol is made up of 95 per cent unleaded petrol plus 5 per cent ethanol (which is why it’s named ‘E5’). E10 petrol is much more beneficial to the environment, containing 10% ethanol and 90% regular unleaded petrol – and was introduced to help the government meet its climate change targets.
The breather hole in the filler neck is very small.
If the fuel was hydrophilic, it would absorb moisture from the atmosphere.
I just cannot see how so much water gets into an apparently sealed pair of tanks except for tiny breather holes which point 45' down. .
Online Grumblebuns
« Reply #8 on: Sunday,May 19, 2024, 10:40:54 AM »
If everything is tight as you say, then plug the overflow vent and the fuel pickup tube and see what happens over time.
Offline Fotog
  • 72 Twin Cam
« Reply #9 on: Sunday,May 19, 2024, 05:20:36 PM »
Don't you have 9 cars, or something like that?  Is it just one of the many?
« Last Edit: Sunday,May 19, 2024, 05:28:56 PM by Fotog »
« Reply #10 on: Sunday,May 19, 2024, 11:40:24 PM »
7 Europas. I had water in one other car's petrol tanks, but not as much as this one.
I will keep checking them if they don't start, by draining the tanks. The water is quite visible at the bottom if it is present.
« Reply #11 on: Monday,May 20, 2024, 03:05:06 AM »
My original fuel tanks leaked water into the tank/tanks through the top of the tank.  Rain comes in through the bonnet screens and lays on top of the tanks where the 1/4" lip doesn't alloy the water to drain.  A rust hole finally appeared.  I lived with it by installing a marine water/fuel separator filter.  The problem was resolved once and for all by installing new aluminum tanks.
I have  not had a problem with  ethanol causing excessive water condensation.
« Reply #12 on: Monday,May 20, 2024, 04:17:03 AM »
I have tested the tops by filling the 1/4" with water. None leaked into either tank after 2 hours. I took the drain plugs out, and the tanks were still completely dry.
« Reply #13 on: Wednesday,May 22, 2024, 05:26:29 AM »
It rained a lot last night.
Car would not start.
I drained both tanks.
Just over 1 pint of water was at the bottom with nearly 3 gallons of petrol on top.
I therefore deduce that the tank tops must be leaking, despite my 2 hour test. I shall seal the tops against rain penetration. Quite how 1 pint even got through the engine cover and on to the tank tops to leak into the tanks is now a bit of a mystery. It just shows how bad the engine cover leaks through the two air vents. Maybe covering those vents when not in use might help. It should also stop water getting into the area around #1 and #2 spark plugs. We keep learning ......
Offline Fotog
  • 72 Twin Cam
« Reply #14 on: Wednesday,May 22, 2024, 07:40:14 AM »
It would be great if you could isolate it to one tank, by disconnecting the second one.  It could be a step toward figuring it out.  Is there any way to see the water in the tank?  You could just isolate them and have a look after a big rain storm (conceivably).  I don't know if you could try to run it on only one if you wanted.  Probably.
