Been rather derailed by family matters over the last month, but have been doing a bit in the garage on and off, to try and progress a little. Gearbox drained of oil and refilled, taking 1.75 litres (3pints), the amount that drained out was a rather sub-optimal litre, but all gears were engaging ok so fingers crossed. The release lever operates very stiffly at present, presumably another effect of having sat so long, having read Dazakman's threads on this, I have sprayed penetrating oil into the tube where the rod pivots, and will have to see if I need to take it all apart once that's had a chance to take effect. I will of course be cleaning up the bellhousing once this is all done.
In other general woes, the bolt that held one of the radius arms to the chassis is refusing to part company with the arm. I had to cut it to get it off the chassis, and so far neither application of heat and plusgas, nor welding a nut onto the end of the bolt and using my impact wrench to try and shock it free have made any, er, impact. I think I am going to have to resort to drilling out the bolt - deep joy.
The cobalt drills I used for the door hinges are making slow headway so far, so I may need a couple of new ones. Got to keep persevering. And buying more shiny bits as retail therapy, that I won't need for ages. Ho hum.
*UPDATE* - the penetrating oil did its magic overnight, and the clutch lever moves forward and springs back like it is supposed to do, so I'm not planning to take it apart any further, just clean up the inside of the bellhousing. Ordered more cobalt drill bits to try and make more impression on the radius arm mounting bolt. Feel the positivity!
