Author Topic: Faulty Distributor Cam Lobes  (Read 4143 times)
« on: Friday,April 26, 2024, 04:28:34 AM »
After driving 4259R for 25 miles, it came to a halt 2 miles from home, and won't start.
I checked all the jets in the 40DCOE Webers, the float level, the pump action was squirting properly, the 4 spark plugs were clean and firing, but the engine just would not start.
I checked the timing, and it was slightly out on #1 cylinder, so I set the light to go out at 8'BTDC, so that is when the points are opening, and the coil would be firing.
I tried to start it, but nothing.
I checked the timing again, but this time, by mistake, I was checking the timing on #4 cylinder, not #1.
I have a vertical line drawn on the big alternator pulley that is perpendicular at TDC on #1, and is 180' out when firing on #4 cylinder, so I was checking #4 thinking it was #1.
#4 was firing at TDC so I rocked the car in 1st gear, and checked #1, and that was firing at 8'BTDC. I have no way of knowing what the reading was on #2 and #3 cylinders, as I was checking TDC from the markings on the flywheel.
I have now fitted another distributor, and timed it at 8' BTDC. I am charging up the battery again to see if it will burst into life. If not, I have run out of ideas.
I have never known a distributor to have faulty cam lobes. I checked to see if the shaft was wobbly, but it seemed to be perfectly straight so no eccentricity from faulty bearings.
Re: Faulty Distributor Cam Lobes
« Reply #1 on: Friday,April 26, 2024, 06:32:35 AM »
Whoopee, another success today. First, DVLA seem to have acknowledged they made a mistake with 3089R, then I got 4259R started after finding out the distributor lobes were wonky.
I am on a roll, what about buying some lottery tickets for tonight !!! £130m jackpot.
P.S. Lottery tickets bought ...............
« Last Edit: Friday,April 26, 2024, 07:23:30 AM by 4129R »
« Reply #2 on: Friday,April 26, 2024, 06:41:45 AM »
 :beerchug:
  Funny how our europas' spread joy.  :FUNNY:
 Pass some of that good luck over this way.
« Reply #3 on: Friday,April 26, 2024, 10:04:02 AM »
Awesome! Just think of how many more Europas you could buy with that.
« Reply #4 on: Friday,April 26, 2024, 11:36:56 AM »
Evijas are only $2.3m each !!!
« Reply #5 on: Saturday,April 27, 2024, 02:47:23 AM »
Did you win......
« Reply #6 on: Saturday,April 27, 2024, 06:37:40 AM »
Did you win......
Sadly my investment enriched others.
But the car started easily and ran well today. The "to do" list has no major items on it.
« Reply #7 on: Saturday,April 27, 2024, 03:12:09 PM »
  Dang, I'm JEALOUS,  I chickened out on driving mine today, because as you just stated I also have no major items .
  Best of luck with her.
Dman
