Author Topic: '74 TCS FS on CL in El Cajon CA. Previously discussed eBay car being flipped!  (Read 2419 times)
Offline FourLoti
This just popped up on CL: https://sandiego.craigslist.org/csd/cto/d/el-cajon-1974-lotus-europa-special/7733566526.html for $29,900.
It's the same car we discussed a few weeks ago https://www.lotuseuropa.org/LotusForum/index.php?topic=6390.0
that ended up selling on eBay for, presumably $20,000.  https://www.ebay.com/itm/186305659831
Only difference I can see is 11 more miles, five new Minilites, more dirt on the console, and, for some reason looks like more front ride height?
Ron
1974 TVR 2500M
1987 Esprit Turbo (gone)
1980 Eclat (gone)
1963 Elan S1 (gone)
1970 Europa S2 (gone)
Re: '74 TCS FS on CL in El Cajon CA. Previously discussed eBay car being flipped!
« Reply #1 on: Thursday,April 04, 2024, 06:52:04 AM »
Front is extremely high
« Reply #2 on: Friday,April 05, 2024, 06:41:45 AM »
Here's the CL listing in case it gets closed out.
Offline FourLoti
« Reply #3 on: Friday,April 05, 2024, 07:45:43 AM »
Still has that curious positive battery cable bypass........
1974 TVR 2500M
1980 Eclat (gone)
1963 Elan S1 (gone)
« Reply #4 on: Friday,April 05, 2024, 03:13:03 PM »
I did the same cable relocation with my TCS many years ago but I've forgotten the reason. At the time I was chasing down an intermittent starter issue where the starter solenoid would click without turning the starter motor over. I remember the positive cable being in fairly bad shape with a lot of corrosion on the lug and in the strands. In replacing the cable I decided to run the cable similar to what the red TC owner had done. I don't recall if it was due to just being lazy or to keep the cable away from the header. Anyway, the new cable did not solve the starting issue if I recall correctly. I found a picture showing the battery cable (at the time, black was the only color I could find) after pulling my engine.
« Reply #5 on: Friday,April 05, 2024, 03:13:12 PM »
  I really never paid attention to the differences in the turn signals , and all those legends where my Hi beams and low oil pressure are.
« Last Edit: Friday,April 05, 2024, 03:15:11 PM by dakazman »
