Another minor job turned into a all day affair.
a simple ground cleaning with a power antenna module swap-out turned into a nightmare.
Sorry, I have maybe some pics of the area that I can post, but I just wanted to complete this job. To get the antenna out the battery needed to come out, no problem until the hold-down bolt snaps off. then I remove the tray that holds it down and find everything rotted out. No problem ,I remove the tray...
then I have to make up a plate to hold the battery in place. Two hours later everything going back together , Maybe. The universal fit antennas mask is to short and its wiring is not anything like OEM. anyway its back together except for the connections to the radio. tomorrow is another day.
