Author Topic: 336 speedometer drive solutions?  (Read 1560 times)
« on: Sunday,March 03, 2024, 10:46:08 PM »
Tried search but could not find the answer I remember seeing.
Someone had been able to mount a pulse generator directly to the transmission.
With that solved this becomes my preferred solution as I do want to be rid of the long failure-prone cable but also want my original speedo.
https://www.summitracing.com/parts/dak-ecd-200bt-1
Dakota Digital unit that would mount behind the dash and drive the mechanical speedometer via a short cable.
I used one in my chevy pickup and it worked well.
I do not have any original transmission speedometer drive parts but I do have an R16 drive piece, which has no right angle.
Offline kram350kram
Re: 336 speedometer drive solutions?
« Reply #1 on: Monday,March 04, 2024, 06:43:00 AM »
I used a direct drive speedometer 12vdc motor affair to drive the stock speedo in my TCS. Uses GPS. Buddy use same unit in his Elan. I have some pictures of the install and the manufacturers data. Need to dig it out. Will post later.
« Reply #2 on: Monday,March 04, 2024, 07:48:49 AM »
I think in 40+ years of Europa ownership, I've only replaced one speedo cable along the way.  Key to keeping it working is removing as much stiction in the rotation as you can (new cables are teflon lined, so it helps, but hanging it up by one of the ferules and filling with a thin oil and letting it drain through helps) and having as WIDE a bending radius both at the back where it hooks into the tranny and at the front where it comes up from the tunnel and has to make a 180 degree bend to get into the back of the speedo is also necessary.
When I did 693R back when...I sourced an MGB right angle speedo adapter (their drive is picked off the tail of the tranny and poke through the tunnel and loop up to the driver side (LHD); on the back of their speedo (at least the pre-'67 or so) was a gear box that translated the drive 90 degrees.  Of course, their cable is only 24" or so...ours have a longer distance...but, it was a simple fix (693R's was the only cable I replaced) that reduced the number of radii the cable had to have to get from the front to the back.
Just a thought...afaik, the current owner still has a working speedo...17 years later...
« Reply #3 on: Monday,March 04, 2024, 04:05:51 PM »
You can use a commonly available ford part that does the trick.  Just slides right in.  I’ve mentioned it before so you should be able to search the archives.  I’m travelling right now but will post it when I get back if you haven’t already found it by then.
Offline kram350kram
« Reply #4 on: Monday,March 04, 2024, 06:49:03 PM »
Richard 48Y... I used the Speedbox by SpeedHut, same type unit you posted. I could not use a  straight cable and bending the cable 90 degrees seemed to acute, because of my gas tank placement. So I placed the drive motor directly behind the speedo thru the firewall with a cover. Fabricated a short coupling to connect the speedo to the drive unit.  Used a Polaris speedometer drive part# 3280017 , 2.25” long from a snowmobile. Best I can do with photos as it's all inplace now.
« Reply #5 on: Monday,March 04, 2024, 08:04:25 PM »
I replaced my original speedo with an electronic Smiths speedo. I ended up driving it with a GPS antenna mounted in my engine compartment (along with some other electronics). It works great but there is a downside. It takes a couple of minutes to acquire enough satellites after I leave my garage before it can register my speed (and mileage) and when I start under tree cover, it can't acquire the satellites till I get into a clearing for a long enough period of time to acquire them. There is some logic in the antenna that remembers (for a limited time) where the last satellites were so when I park, it doesn't take any time to acquire them so it's really only a problem when I first drive away.
Over all, I'm really happy with it. As you've found out, there are many ways to skin this cat. The electronic driver driven by the speedo gear in the tranny is maybe a better alternative but I shredded my speedo gear so that wasn't an option.
« Reply #6 on: Monday,March 04, 2024, 08:08:52 PM »
I think I found the discussion of the Ford impulse sender.
Should work fine so long as the 336 and 365 are the same?
I also saw new 12T drive gears at R16 shop.
Hoping to pull parts and delve into this a bit more in the morning.
I know my 336 transmission has an empty hole with a plastic cover over it.
Offline 314159td
    • Project Portfolio
« Reply #7 on: Thursday,July 11, 2024, 10:18:42 PM »
Reviving the most recent incarnation of this...
I have a shredded 336 speedo drive gear, saw the same one on r16 shop.
Mine, and some others I see marked as 336, seem to have a different drive on the end of the shaft. The R16 one looks to be some kind of two-spline affair, like a rotary hammer.
Mine is just a simple slit cut in the shaft to drive a flat tang on the 90* box.
I assume the 336 is different from other, later 4-speeds? Or the stock Renault uses a different drive to their speedometer cable? (then why would r16 shop advertise it for the Europa?)
What is the difference between these two?
I also see the individual gear for sale on R16 shop, but question yanking the shaft off my gear and transplating that to another.
« Reply #8 on: Friday,July 12, 2024, 01:25:50 PM »
The upper one is the correct style.  Don’t know about tooth count.  It takes a squared-ended cable.  The lower ones mate to a cable with a flat tang drive, like the tip of a flat screwdriver.
Offline 314159td
    • Project Portfolio
« Reply #9 on: Friday,July 12, 2024, 01:31:09 PM »
The lower style is the kind that came out of my gearbox, and what's shown in the parts manuals. I assume the upper style fits a different 336-XX or a 352?
« Reply #10 on: Friday,July 12, 2024, 01:39:26 PM »
Do you have the original tranny?
Offline 314159td
    • Project Portfolio
« Reply #11 on: Friday,July 12, 2024, 02:13:09 PM »
As far as I know it should be the original unit, it's a 336-20 with the angle drive and early style engine mount. The engine did come out at some point, so it's possibly a swap, but I doubt it. Engine # matches the VIN plate.
He's the S1 workshop manual page I'm looking at, and my actual speedo gear
« Reply #12 on: Friday,July 12, 2024, 06:52:24 PM »
I changed my tranny and never looked closely at the original.  Check your angle drive.  If it seized, it’ll be why your gear died.
Offline BERNIEHUMBER
« Reply #13 on: Monday,July 15, 2024, 08:00:12 AM »
HI:
I have an S2 1969 and I also had a speedo gear issue back in the day.
I 3D printed a copy using PLA material.
You can see from the pics the original(blue and beat).
I heated the drive shaft and withdrew it from the original.
I used a slight force fit (and slightly heated the "new" gear) to get the replacement.
I installed it and ran it a while just to see the outcome.
What you see in the pic is the replacement after a run or two(looking good).
I taught in a college before retiring(4 years ago) so I had access to printers and a full machine shop.
Offline 314159td
    • Project Portfolio
« Reply #14 on: Monday,July 15, 2024, 10:51:41 PM »
Huh, I wouldn't have expected FDM printed PLA to hold up that well.
I've printed a good number of gears for woodworking equipment in PETG and those have been doing good enough, so I suppose it's not too crazy.
Would you happen to still have any design files or drawings floating around? I was literally just launching Solidworks as I saw this.
A statistically unusually number of Europa owners seem to be engineers...
