Author Topic: Vht wrinkle paint on tc valve cover  (Read 1946 times)
Re: Vht wrinkle paint on tc valve cover
« Reply #15 on: Saturday,February 24, 2024, 07:08:50 PM »
I would definitely use Hylomar.
Been using it for years and rarely use anything else now.
« Reply #16 on: Tuesday,February 27, 2024, 05:17:35 AM »
I use ultra black to stick the gasket (which I got from England and is cork/ rubber and is less squishy) to the head.  The top of the gasket is dry with a little ultra black on and around the cam seal.  I then torque the nuts very slowly and evenly with a low range torque wrench to 5 foot lbs.
It has never leaked since adopting this method a number of years ago.
Offline Fotog
  • 72 Twin Cam
« Reply #17 on: Tuesday,February 27, 2024, 01:30:24 PM »
Sounds like as with many things there is not just one best way.
Thanks for the info!
Vince
« Reply #18 on: Tuesday,February 27, 2024, 01:42:21 PM »
As with many things, there are lots of ways to skin that cat!
« Reply #19 on: Tuesday,February 27, 2024, 03:13:38 PM »
I think the composite rubber/ cork gasket is more robust and less compressible than the all cork gasket.  It is prone to squish out when torque.
Other than that, the methods look similar.
