Author Topic: Which NG3 is this?  (Read 2204 times)
Which NG3 is this?
« on: Tuesday,January 30, 2024, 06:32:43 PM »
Can anyone tell me which NG3 this is?
Re: Which NG3 is this?
« Reply #1 on: Tuesday,January 30, 2024, 07:00:41 PM »
The tag will have the type of tranny (NG1, NG2, NG3, or NG5). Then there will be a “suffix” that will be three digits which tells you what ratios it has, and then there will be a serial number. Here’s a manual that tells you more: http://lotus-europa.com/manuals/misc/ng.pdf
« Reply #2 on: Tuesday,January 30, 2024, 07:19:15 PM »
I don’t see a 065 (?) in that list  :confused:
« Reply #3 on: Tuesday,January 30, 2024, 07:40:37 PM »
There's another manual with a larger list of suffixes (http://lotus-europa.com/manuals/misc/MRBVNG.pdf) but I don't see 065 anywhere either. Maybe I missed it? There is a 065 and 067! Does it say NG3 on it?
Offline Blitzen
« Reply #4 on: Wednesday,January 31, 2024, 03:17:06 AM »
065 is in last section, for USA & Canada ratios . Page 13 of the NG manual
« Reply #5 on: Wednesday,January 31, 2024, 03:35:22 AM »
Thanks Blitzen! What is vehicle 136A ? A Fuego of some sort I assume?
« Reply #6 on: Wednesday,January 31, 2024, 08:09:52 AM »
I couldn’t find a reference to 136A in either of the manuals but I found it here (https://vehicleidentificationnumber.com/vin-decoder/renault-car.html). It’s a 1600cc Turbo Fuego.
« Reply #7 on: Thursday,February 01, 2024, 03:31:58 PM »
So, this is worth pursuing?
« Reply #8 on: Thursday,February 01, 2024, 03:47:23 PM »
Absolutely! :beerchug:
« Reply #9 on: Tuesday,February 13, 2024, 05:07:44 AM »
Still working out the details on this in case the 352 transaxle doesn't like having a turbo hurrying it along ....  ???
« Reply #10 on: Tuesday,February 13, 2024, 09:03:42 AM »
Aren’t the number of planet wheels an indication of how much torque the box will take? The 336 and 352 have two I believe and the 365 and NG3 have four. Interestingly, in their SCCA racer, Jensen Motors used a 336 with straight-cut non-synchro gears. Are you expecting to generate much more torque than a race engine?
« Reply #11 on: Tuesday,February 13, 2024, 09:07:44 AM »
Boost usually bumps up the torque!
« Reply #12 on: Tuesday,February 13, 2024, 09:24:43 AM »
I thought the 365 also only has 2 planet gears. I have a 365, so I want to be clear about this for future reference.
« Reply #13 on: Tuesday,February 13, 2024, 09:54:05 AM »
Agreed, but any idea how much?
Wild ass guessing, they got in the neighborhood of 200bhp at 8000rpm. Obviously hp and torque peaks happen at different rpms but I think we can expect that the torque does not fall off a cliff so the torque at 8000rpm is in the neighborhood of 130 ft-lbs.
T=hp/rpm    rpm is in radians/sec  (6.28 * 8000/60)
                   hp is 550 ft-lbs/sec (200 * 550)
Since Jensen didn’t mention any maintenance on the tranny, we might conclude it was not a weak point and their 336 could handle more torque. Arbitrarily, maybe 150 ft-lbs might be a reasonable upper limit…
If all that is reasonable, maybe we could expect an NG3 to handle over 200 ft-lbs.
Just as a comparison, my BDA maxes out at 125 ft-lbs and generates 177bhp @ 7500rpm.
edit: obviously all math and assumptions checks are welcome!
« Last Edit: Tuesday,February 13, 2024, 10:08:03 AM by BDA »
« Reply #14 on: Tuesday,February 13, 2024, 09:58:15 AM »
Kendo, check Fig. 69 on page 36 of the manual (http://lotus-europa.com/manuals/tcwork/f/tcf.pdf).
