Author Topic: Fuel level sensor wiring  (Read 472 times)
« on: Monday,January 22, 2024, 11:56:49 AM »
I moved the level sensor and wiring from the left to right tank as I am running one tank for now.
The original black wire to the sensor has no continuity to ground for some reason. The left tank’s original ground wire does, will the gauge/level sensor be fine using this ground (I am no electrician)? I think it will but I want to check.
Re: Fuel level sensor wiring
« Reply #1 on: Monday,January 22, 2024, 12:31:24 PM »
You will have to ground the sender otherwise it won't work. Is that what you're asking?
« Reply #2 on: Monday,January 22, 2024, 01:36:58 PM »
I think that is what I am asking ::)
« Reply #3 on: Monday,January 22, 2024, 02:49:53 PM »
   The grounds for that go through the cabin light. Provide a separate ground from sender to a ground stud you select. Then you can swap the sender from tank to tank and take the cabin light out of the picture.
  The more grounds the merrier.
« Reply #4 on: Monday,January 22, 2024, 03:38:03 PM »
Thanks D'Man!
