Author Topic: Renault engine thrust washers source in the USA?  (Read 772 times)
« on: Thursday,December 21, 2023, 08:03:10 PM »
All I could find in stock were 0.010" oversize and too thick.
Re: Renault engine thrust washers source in the USA?
« Reply #1 on: Thursday,December 21, 2023, 10:40:17 PM »
Email sent to Alpine America, fingers crossed.
RD Ent. does not show them and Dave Bean only has the oversize.
Offline Triton
« Reply #2 on: Friday,December 22, 2023, 02:14:16 AM »
I don't know what they look like but maybe you could get the oversize ones thinned down on a  Magnetic Grinder.
« Reply #3 on: Friday,December 22, 2023, 06:08:11 AM »
Too thick by how much, Richard?
If only a few thou, that can be done with some wet 'n' dry on a surface plate.
« Reply #4 on: Friday,December 22, 2023, 07:41:50 AM »
It’s not a shim.  It’s a steel-backed and babbit-plated.
Usually only one side is worn, the side that takes the thrust from the clutch.  You can try fitting the “good” old one with a new oversized one.
« Reply #5 on: Friday,December 22, 2023, 08:17:07 AM »
Alpine America closes from October to May. I think it’s highly unlikely you’ll get a reply but hope springs eternal. In the meantime, I’d look elsewhere like Meca Parts or Renault16Shop.com or maybe a Renault dealer in England.
I had a hard time finding a bearing for my tranny and was finally able to get one from olivier@ateliermahoa.com.
« Last Edit: Friday,December 22, 2023, 10:34:54 AM by BDA »
« Reply #6 on: Friday,December 22, 2023, 09:38:18 AM »
Salve Sacco has them.
I will need to add a few other small parts to justify the postage.
« Reply #7 on: Friday,December 22, 2023, 07:10:53 PM »
Hi JB,
Yep and you'd remove material from the steel backing.
A cam shim is a an entirely different application and I wouldn't be altogether confident of being able to maintain parallelism in the home shop for such a small hardened item. Nevertheless, people do it and seemingly have little trouble. A cam shim is also subject to high point loads a thousand times every minute whereas a thrust washer bears a much lighter load and infrequently.
A motor engineer friend showed me how to make custom bronze thrust washers for a Lotus 912 engine where the thrust flange on the crank needed to be refaced (long story). The machining put the required thrust washer dimensions well out of range of any available stock items.
I asked him - what about the white metal facing? He said: If you like, put a series of divots on the face with a small drill for oil retention, but it'll be fine either way - and it was.
Ray was a well respected builder of drag engines among others and he showed me the Austin Healy 3000 he'd converted with an alloy OHC Ford cylinder head. This sort of engineering adventurism was his stock in trade. I just went along for the ride.
So, from my experience (and guidance from Ray) I reckon it's entirely viable to tackle a thrust washer thickness issue using common sense, a surface plate, a micrometer and a tube of engineer's blue.
But yeah, I like the idea of using the old “good" thrust washer if the clearance then fall within range.
