Author Topic: Twin Cam value  (Read 768 times)
Offline Kenno320
Twin Cam value
« on: Monday,November 27, 2023, 05:29:12 AM »
 I have a Weber head Twin Cam engine that is currently installed in my ‘67 Elan DHC. It was installed a few years ago while the car belonged to a friend of mine. The original engine had seized, and this was put in its place.  I subsequently bought the car and original engine, and then had the original professionally rebuilt.
After I put the originally engine back in, I will be selling the other one, but I have no idea what it’s worth.
The Weber head was rebuilt by a guy who specializes in TC’s, and was rebuilt to big valve specs.  The engine itself was reassembled by myself and a mechanic friend. The block was cleaned and tested prior to assembly, and all of the clearances (bearing, valve, ring, etc.) were properly checked.  It has a six bolt crank, but I don’t remember if it had square or round caps.  I will check that out after it is pulled. Pretty sure it has “B” cams, but I will check that out as well.  Currently around 600 miles on the engine.
Does anyone have any thoughts on this?
Anyone interested?
Engine is in Minnesota, but I can crate it and ship it anywhere.
I also have the Europa alternator pulley, but not the Europa cams.
Re: Twin Cam value
« Reply #1 on: Monday,November 27, 2023, 08:37:53 AM »
You would need to change the inlet cam, cut a groove in the head and cam cover for the cam oil seal which means head off, and change the water pump for a Europa pump, front exit not side exit.
Europa pump housings are made from unobtanium.
Offline Kenno320
Re: Twin Cam value
« Reply #2 on: Monday,November 27, 2023, 09:29:07 AM »
Thanks for info.  I had forgotten the extent of the mods.  A number of years ago I purchased a '68 Elan FHC that had a Europa engine in it, so I knew they were somewhat interchangeable.
Re: Twin Cam value
« Reply #3 on: Monday,November 27, 2023, 12:32:42 PM »
Presumably you've advertised the engine in the Elan, Escort, Cortina, Lotus 7 world?
My advice would be to sell the engine while it can be seen installed & running by a potential buyer.
That way, the buyer can properly assess the state of the engine. He might want to do a leak down test or compression test, for instance.
If it's just an engine on a pallet, most people will put it into the "ran when parked" category and value it accordingly - less money.
My $0.02
Offline Kenno320
Re: Twin Cam value
« Reply #4 on: Tuesday,November 28, 2023, 06:15:11 PM »
That’s a great idea!  Thanks!
Offline s2europa
Re: Twin Cam value
« Reply #5 on: Wednesday,November 29, 2023, 02:43:23 PM »
What block is the engine? 120E, 701M, etc. Pictures? Maybe a video of it running would help. Thanks.
Offline Kenno320
Re: Twin Cam value
« Reply #6 on: Wednesday,November 29, 2023, 07:46:55 PM »
I’ll see if I can do that this weekend
Offline Kenno320
Re: Twin Cam value
« Reply #7 on: Tuesday,December 05, 2023, 07:56:41 PM »
681F6015 “L” block.
Pictures and video can be seen through this link:
https://photos.app.goo.gl/ZHbcSxJHVEihXJWFA
I’m thinking that $5900 would be a fair price for a running engine
