Author Topic: Miscellaneous Twin Cam parts for sale  (Read 1029 times)
Offline Kenno320
« on: Saturday,November 25, 2023, 11:27:19 AM »
Available for sale:
Crankshaft
Cam sprockets (intake, exhaust, and jackshaft)
Jackshaft
Crankshaft pulley
Connecting rods
Stromberg air box
Stromberg secondary throttle plates (2)
Europa alternator pulley
Used starter
Brake pads - one new set, one slightly used set
Flywheel gear ring
Steering wheel spokes
Front vertical link - I do not know which side. Hopefully someone with a good eye can tell.
Here is a link to the photos: https://photos.app.goo.gl/X83aoMdtz6x2utKs8
**UPDATE**
ConRods are sold
Crankshaft is sold
Both secondary throttle plates are sold
Make offer.
kenno320@icloud.com
« Last Edit: Monday,February 19, 2024, 06:30:22 AM by Kenno320 »
Re: Miscellaneous Twin Cam parts for sale
« Reply #1 on: Saturday,November 25, 2023, 01:22:19 PM »
PM sent.
« Reply #2 on: Saturday,November 25, 2023, 01:32:17 PM »
The left hand vertical link has left hand threads for the trunnion and the right hand vertical link has right handed threads for the trunnion.
« Reply #3 on: Saturday,November 25, 2023, 01:48:55 PM »
Is that Stromberg air box from an Elan? It looks different from the one I have
Offline Kenno320
« Reply #4 on: Saturday,December 23, 2023, 04:53:20 PM »
Actually an Elan airbox.
« Reply #5 on: Monday,January 01, 2024, 05:18:10 AM »
With the idea of getting the cool air from low in front of the right gas tank, has anyone fitted an Elan Stromberg air box to an Europa? Does the angle of the box’s air inlet work for plumbing into the lower corner there? If it worked, it would be much simpler than constructing my own air box.
« Reply #6 on: Tuesday,January 02, 2024, 10:26:48 AM »
Doubt the angle is right.  You'll have to modify it.  Not that hard, really.  I modified and fit a TC airbox to my Renault crossflow powered S1 to achieve what you are wanting to do.
https://www.lotuseuropa.org/LotusForum/index.php?topic=3684.msg38896#msg38896
