Author Topic: Europa rear diffuser  (Read 503 times)
« on: Saturday,November 25, 2023, 05:32:22 AM »
Found this today .... http://www.amdl.co.uk/europa/europa.htm ... notice it is on a Twin Cam with rear panel cut out like an early car ...
Since it is Banks they probably know what they are doing!!
Re: Europa rear diffuser
« Reply #1 on: Saturday,November 25, 2023, 07:21:26 AM »
It’s a pretty simple design, though the support frame would take some doing. I wonder if they would produce more of them if asked? But, a diesel Europa?
« Reply #2 on: Saturday,November 25, 2023, 09:04:28 AM »
NA only got diesel Smarts in the oughties.  Europe had gasoline powered ones as well.  NA got those in 20-teens.  The gasoline engine was what Richard used.  This all nearly 20 years ago, BTW.
« Reply #3 on: Tuesday,November 28, 2023, 02:37:45 PM »
« Reply #4 on: Wednesday,November 29, 2023, 08:56:40 AM »
Looking at the images in the link, it seems on a standard Europa there would need to be a lot of work-around to clear the gearbox and deal with the exhaust.
« Reply #5 on: Wednesday,November 29, 2023, 09:29:30 AM »
That article also idealizes the car to one without suspension. They strongly suggest the diffuser front edge start at the end of the flat floor of the body. That part could be adapted to the Europa underside. But what about the articulating rear suspension? On the other hand, F1 cars must have solved this effectively. So how do they get the diffuser funnel past the suspension? Probably some interesting mechanical design there.
« Reply #6 on: Wednesday,November 29, 2023, 12:19:28 PM »
« Last Edit: Wednesday,November 29, 2023, 06:12:27 PM by TurboFource »
« Reply #7 on: Wednesday,November 29, 2023, 12:50:27 PM »
For some reason your link didn't work. I think this is where you meant to send us:
http://lotus-europa.com/manuals/misc/aero/Europa%20Aerodynamics.htm
« Reply #8 on: Wednesday,November 29, 2023, 02:12:15 PM »
It was BDA , thanx
Offline cazman
« Reply #9 on: Wednesday,November 29, 2023, 03:19:01 PM »
That's a cool writ up.
1973 Europa TCS
