Author Topic: Speedo cable  (Read 501 times)
Offline Sparkrite
Speedo cable
« on: Friday,October 06, 2023, 01:00:47 AM »
My cable works but rattles a bit. Can I simply withdraw it from the gearbox end, clean it and lightly oil it then push it all the way back in.
Re: Speedo cable
« Reply #1 on: Friday,October 06, 2023, 06:09:33 AM »
Usually they come out from the speedometer end.  Other than that, yes, you can.  Use a light-weight grease.
Re: Speedo cable
« Reply #2 on: Friday,October 06, 2023, 07:26:06 AM »
I've had good luck with this stuff, on everything from motorcycle controls, aircraft cables (not the cables themselves, but the pulleys and throttle/mixture/carb heat/cabin heat/fresh air controls), and did my throttle, choke, and clutch in 3291R when I renewed them.  No doubt it would work well for the speedo cable.
Offline Sparkrite
Re: Speedo cable
« Reply #3 on: Friday,October 06, 2023, 10:20:16 AM »
Thanks guys.Ive had a quick look behind the Speedo guage and it's quite a tight fit to get my hand up there,let alone pull out the cable.
Offline Fotog
  • 72 Twin Cam
Re: Speedo cable
« Reply #4 on: Friday,October 06, 2023, 11:07:30 AM »
You can do it, Sparkrite!
Mine broke and I installed a new one.  It has a nylon (or some-such) bush on one end that is a tight interference fit (so it isn't intended to be removed to facilitate installation).  So I had no choice but to put it in from the speedo end.  There are more difficult things to access in a Europa, I'm sure.
Re: Speedo cable
« Reply #5 on: Friday,October 06, 2023, 02:18:43 PM »
  I know you document that you used that per amm. :FUNNY:
dakazman
