Author Topic: No Oil Pressure  (Read 5093 times)
Re: No Oil Pressure
« Reply #60 on: Friday,October 13, 2023, 10:26:01 PM »
great news, another one to file away in the "how on earth did that happen ?" category !
After skipping back through this thread at all the options we've suggested, 20/20 hindsight is a wonderful thing isn't it ?
Re: No Oil Pressure
« Reply #61 on: Saturday,October 14, 2023, 12:25:16 AM »
I have come to the conclusion that the PO put the engine back together again in a hurry just to sell the car.
The Allen key needed to undo the grub screw is 1/4", and I had to buy a 1/4" key as I did not have one that fitted, so I am fairly confident that I did not remove that grub screw.
At least the answer was not expensive, just time consuming. When the engine was out, I found the clutch plate had stuck itself to the flywheel, the screw holding the speedo cable into the gearbox was not long enough to grip it so I fitted a longer one, and it gave me a chance to clean things that had corroded, so all of the time removing and refitting the gearbox and engine was not lost.
Re: No Oil Pressure
« Reply #62 on: Saturday,October 14, 2023, 05:26:06 PM »
Sure is.
It also highlights the process of elimination so essential to the diagnosis.
Great news indeed.
