Author Topic: TCS Shift Linkage Center Bushing - Polyurethane  (Read 16761 times)
Re: TCS Shift Linkage Center Bushing - Polyurethane
« Reply #15 on: Tuesday,August 21, 2012, 11:13:11 AM »
 :trophy:
« Reply #16 on: Tuesday,August 21, 2012, 11:19:28 AM »
I was thinking the very same thing about the jam nut instead of the roll pin.  What I don't get is why a jam nut was not used in the original design...........Input please?
By the way, since I am doing the shift linkage  your writings do give me more insight.  Thanks
« Reply #17 on: Tuesday,August 21, 2012, 01:40:37 PM »
good feedback there, it's nice to hear when there's a successful result.
If you strip the shift lever again, would one of those gap-filling compounds that you use on worn bearing housings be good enough to hold the bronze bush in place ? They don't take up massive gaps, but a few thou' is normally ok.
« Reply #18 on: Thursday,August 23, 2012, 10:47:01 AM »
  Yes, I've been wondering about this as well.
« Reply #19 on: Thursday,August 23, 2012, 11:03:03 PM »
Trying to figure out just why Lotus did things the way they did is the road to madness.... :)
My first guess was that they had a jig to set the roll pin position and so it was easier on the production line. Then came the cost element - they'd have to stock 2 types of nuts and Chapman was known for cutting out cost wherever he could.
But my best guess is that once set at the factory with a roll pin, it was "fixed for good".  Chapman hated people tinkering with "his" cars, always saying that they messed them up and that was why the production cars had fixed dampers, spring platforms, suspension links with no adjustment, etc.  Setting up the shift (as we all know) is a hassle and maybe he just wanted to stop any of the owners/garage mechanics from taking it apart, failing to put it back correctly and giving them headaches with warranty claims ?
« Reply #20 on: Friday,August 24, 2012, 08:23:21 AM »
  There only needs to be one nut for rotational adjustment.
This makes Lotus sense.  If my pin had not worn, then it would have continued to shift as designed, then I would not have tinkered with it, then it would not have been out of adjustment, then I would have never wanted the nut for adjustment...  Good thing nothing else on this car is likely to wear and thus need adjustment.   :BEER3:
