Author Topic: Removing the steel spark plug wells from a cross-flow head?  (Read 496 times)
« on: Monday,September 25, 2023, 11:43:26 PM »
Pretty certain they should be removable, has to be a way.
I expect them to be threaded in but they are not moving and I dare not damage them.
I know mine is not the only TS/Cross-flow here so someone must know the trick.
Re: Removing the steel spark plug wells from a cross-flow head?
« Reply #1 on: Tuesday,September 26, 2023, 01:10:20 AM »
A pure guess here because I've never owned a Renault engine of any sort, but could they be heat shrunk into place ?
The valve guides and seats on the original Lotus TC head are cast iron and to remove or fit those you have to soak the head in a furnace before driving them out. Fitting new ones is the same way, heat up the head, cool the inserts and press them in quickly before they heat up & expand.
« Reply #2 on: Tuesday,September 26, 2023, 01:44:33 AM »
I should probably just ask Salv but I think he is still on vacation.
Offline Bullnose
« Reply #3 on: Tuesday,October 24, 2023, 12:47:37 PM »
Reading through my newly acquired shop manual for the engine there is no mention of removing and replacing the tubes.
All photos and drawings show the tubes in place. So I guess  we'll have to work around them
Grant
Grant
« Reply #4 on: Tuesday,October 24, 2023, 11:35:12 PM »
My TS head arrived at the rebuilders today.
If he finds them to be an issue I expect I will hear about it.
