Author Topic: Child Proof Locks  (Read 744 times)
Child Proof Locks
« on: Thursday,August 31, 2023, 02:35:39 PM »
Just a warning about these child proof locks.
After renovating a TCS, I sat in the driver's seat, but could not open the drivers door.
I had to climb over the centre tunnel and get out of the passenger door, which luckily was not child locked.
Quite why they are fitted to a two door, two seat car, I do not know, but if both doors had these locks clicked to child proof, you would not be able to get out of the car.
Re: Child Proof Locks
« Reply #1 on: Thursday,August 31, 2023, 03:41:26 PM »
If you can turn the ignition on and wind down the window you can use use the exterior door handle with a lot of yoga and an appointment with an osteopath...
« Reply #2 on: Thursday,August 31, 2023, 06:24:34 PM »
  Been there ! They were an eye opener to me also .
« Reply #3 on: Thursday,August 31, 2023, 11:06:35 PM »
Back in the day, child proof locks became popular but only fitted to the back doors of sedans.
Makes me wonder what feature was so special about these locks to Colin.
« Reply #4 on: Thursday,August 31, 2023, 11:34:29 PM »
My ignition switch had just fallen apart. I had thought of that.
New one arrived from Rimmer Bros the next day.
Offline Footer
« Reply #5 on: Monday,September 04, 2023, 07:35:44 AM »
Not familiar with the child proof lock option.  I have a 73 TCS.  It doesn’t seem to be listed in the parts manual.
Could someone point me in the right direction so I can familiarize myself with this function?
Thanks
« Reply #6 on: Monday,September 04, 2023, 08:37:53 AM »
This will be a little lever in the door lock mechanism. Slide it one way, and children can’t use the inside handle to open the door at speed. Or Europa drivers. My ‘73 has it in the lower inside corner of the door-side mechanism.
« Reply #7 on: Monday,September 04, 2023, 09:35:08 AM »
The way to find out if the child lock is on, is to pull the black plastic inside door opener, with the door open, and if it moves freely, the lock is off.
For the record, if the little metal lever is down, the child lock is off. It is a very small L shaped lever which goes over the white plastic part of the door lock mechanism which engages with the metal hoop.
So down = off, up = on, or upon !
« Reply #8 on: Monday,September 04, 2023, 11:03:39 AM »
I will be removing them from my car.
Cannot think of another item so useless but possibly troublesome.
Offline Footer
« Reply #9 on: Tuesday,September 05, 2023, 09:09:54 AM »
Found them .  Thanks!   :trophy:
« Reply #10 on: Tuesday,September 05, 2023, 09:18:43 AM »
Brake boosters on a Twin Cam...?
Offline cazman
« Reply #11 on: Tuesday,September 05, 2023, 10:18:51 AM »
 :beerchug:yup
1973 Europa TCS
Online Bryan Boyle
« Reply #12 on: Tuesday,September 05, 2023, 10:48:14 AM »
Got caught with them in the wrong position once...while the car was on a trailer!   Fun times.
I just put the lever in the non-child-proof position and use a dremel cutoff wheel to remove the visible part of the lever.  Problem solved (unless you get into the opening with a small screwdriver and flip it).  Have never had a problem since.
Offline FourLoti
« Reply #13 on: Tuesday,September 05, 2023, 11:37:49 AM »
Plus One for Dremel!
« Last Edit: Tuesday,September 05, 2023, 11:39:59 AM by FourLoti »
1974 TVR 2500M
1987 Esprit Turbo (gone)
1980 Eclat (gone)
1963 Elan S1 (gone)
1970 Europa S2 (gone)
« Reply #14 on: Wednesday,September 06, 2023, 12:30:55 PM »
On the 1970 S2's I am working on the silly locks are at the upper inside corner of the latch and Down is Off.
Chop - Chop!
