Author Topic: Hello from a new Europa S2 owner  (Read 1057 times)
Offline aboezaard
  • Restoring an S2
Re: Hello from a new Europa S2 owner
« Reply #15 on: Saturday,August 26, 2023, 12:34:09 AM »
Cropped your pic for easier viewing.
This site does not automatically resize pics.
Glad to see another S2.
Thanks, but you cut my racecar off ;) the E30 I build also from scratch.
« Reply #16 on: Saturday,August 26, 2023, 12:56:34 AM »
I would recommend that you replace cooling pipes with stainless steel. The old won't get any better. I'll be doing mine when/if I have engine out. Don't forget to do heater hard lines at the same time.
I have flushed mine, and radiator, for now. A lot of rust flakes had stuck to inside of rubber hoses to. When I squeezed them when they were off they would crunch and drop flakes out of them!
« Reply #17 on: Saturday,August 26, 2023, 12:32:25 PM »
I agree 100%. Best get rid of the thin, steel originals. There are both stainless and aluminum solutions available, or get a local shop to make up a set. When my engine comes out for any reason, I'll be tackling that job myself.
Offline aboezaard
  • Restoring an S2
« Reply #18 on: Wednesday,August 30, 2023, 01:33:49 AM »
The shipping and tax cost are huge for new cooling lines so I decided to create them myself.
I asked a local shop to bend some alu tubes, they want a drawing of the lines. Is there a drawing available somewhere of these cooling lines?
« Reply #19 on: Wednesday,August 30, 2023, 09:13:02 AM »
You can use aluminum straight tube on both if you don't mind drilling a few more holes. I did one aluminum straight and pieced together a stainless one from an MR2 for the bent one. To do again, I would run two straight through.
« Reply #20 on: Wednesday,August 30, 2023, 09:36:43 AM »
I have all the parts, the car is complete for what I can see. I bought it in boxes, so it is a big puzzle.
The only thing I am missing Is a left hand door quarter glass. This one broke unfortunately in transport. Do you have any idea where to find this?
[/quote]
  This might be a longshot  , Ill PM you
  Dakazmzn
Offline Footer
« Reply #21 on: Wednesday,August 30, 2023, 05:45:35 PM »
Welcome to the sight and good luck with your Europa.  I too would recommend that you replace the old steel lines with aluminum or stainless.  I made the mistake of not doing that and very shortly after I put the motor back, pressure in the line found the spot where rust had weakened the line and I had coolant all over the motor and road.  Now that you have access it would be a fairly simple job.  Keep looking for replacement pipes, they will show up.  Unfortunately they will be expensive
« Reply #22 on: Wednesday,August 30, 2023, 09:20:11 PM »
Funny this should come up, I've decided to buy dies for my bender and make my own as shipping is just silly now.
I have the old set to copy, not certain they are original as they are three pieces.
UK price was pretty good at £220, but £550 shipping is impossible.  :headbanger:
Offline RobbartK
  • 1970 S2 eBay purchase. His name is Woodstock.
« Reply #23 on: Saturday,September 09, 2023, 05:25:38 PM »
Greeting from Woodstock and me.
Rico = 2003 Jeep Wrangler
Idefix = 2018 Fiat 124 Spider Lusso.
ButtrBus was my 1985 VW Vanagon.
JAKRBT was my 1975 MGB roadster.
MyJul was my 1999 VW Cabrio.
I never named my 1948 Ford F1... my wife made me sell it.
My wife drives a 1994 Ford Crown Vic and loves it.
Offline aboezaard
  • Restoring an S2
« Reply #24 on: Sunday,October 08, 2023, 06:47:25 AM »
Thanks, I will have a look.
