Author Topic: TC fuel pump fitting  (Read 398 times)
Offline Blitzen
« on: Tuesday,August 15, 2023, 10:14:05 AM »
Does anyone know what the fitting is for the inlet of the glass bowl fuel pump?
Re: TC fuel pump fitting
« Reply #1 on: Tuesday,August 15, 2023, 11:36:51 AM »
Just a standard imperial compression fitting AFAIK.
Offline Blitzen
« Reply #2 on: Tuesday,August 15, 2023, 12:23:28 PM »
Trying to figure out what fitting I need to connect braided hose to pump.   They have AN to 1/4” hardline (compression) adapters but I’d prefer to eliminate the hardline and connect the hose directly to the pump.   Not sure if this is possible.  Definitely want to eliminate all the plastic hoses.
« Reply #3 on: Tuesday,August 15, 2023, 01:35:45 PM »
I have always used copper pipe, brass connectors and Ts, and rubber tube, for all my tank to pump,  and carb to carb, connections.
