Author Topic: Engine compartment paint?  (Read 766 times)
« on: Sunday,August 06, 2023, 06:32:10 AM »
I was wondering what people have been using to paint their engine compartments?
It would have been easier to do this before I lowered the body onto the chassis yesterday but standing on a ladder to do such things does not appeal to me :-\
Re: Engine compartment paint?
« Reply #1 on: Sunday,August 06, 2023, 08:24:27 AM »
  I had enough base coat paint every time I painted a panel. Of course I went to extremes and sanded the compartment smooth after troweling on a mixture of resin and glass fibers.
  Are you going to paint the firewall also ? If so just use Krylon color max . I used this in the front radiator area.  Your choice of satin, flat or gloss.
Offline My S1
« Reply #2 on: Sunday,August 06, 2023, 09:01:04 AM »
I have found that Rust-oleum Flatt Black #7776 when brushed on blended perfectly with the original, unrestored front compartment black.  The brush marks blend with the raw fiberglass matt fibers.  It is oil based and takes a while to dry but after a few days the sheen dulls down.
« Reply #3 on: Sunday,August 06, 2023, 09:05:11 AM »
Thanks for the replies!
« Reply #4 on: Sunday,August 06, 2023, 05:59:15 PM »
I am still thinking I will use blue/grey Zolatone.
May use a similar bed liner.
Not liking black as I like to be able to SEE in the engine compartment.
Car is modified anyway so this minor indiscretion should be OK.
« Reply #5 on: Sunday,August 06, 2023, 06:05:41 PM »
Richard,
I am considering gray also.
Online kram350kram
« Reply #6 on: Sunday,August 06, 2023, 06:47:42 PM »
+1 on Zolatone. Covers a multitude of surface imperfections.
Offline Lotuswins
« Reply #7 on: Monday,August 07, 2023, 03:10:09 PM »
+1 on the flat black Rustoleum, though I used a rattle can.  Matches original paint perfectly, but I blasted the old off since it was flaking badly.  Easily touched up too.
Jerry Rude
4005R
« Reply #8 on: Monday,August 07, 2023, 07:25:09 PM »
  I like shiny!  Smooth and easy to clean. It footage long.
« Reply #9 on: Tuesday,August 08, 2023, 03:33:17 AM »
That looks great D’man!    How long did it take to get it so smooth?
« Reply #10 on: Tuesday,August 08, 2023, 03:57:59 AM »
  I’m going to say 16 hours . First sand with 60 grit, just to get the high and loose fibers off, then trowel on resin with mixed in “fiber dust” . Like sawdust particles but glass particles, or just use veil.
Then sand with 180 , prime., sand , prime sand and paint. It actually smells better than the dirt smell of some cars.
« Reply #11 on: Tuesday,August 08, 2023, 06:31:56 AM »
I've done a few cars (I know...sound like a broken record...) with bed liner.  A lot more durable than rattle can (not that there is anything wrong with rattle cans, just preference) and the satin finish hides a multitude of sins.  Learned the trick of using it when rebuilding 693R, and had to splice in the openings to the rear suspension cross member in the rear to repair a (D)PO's hack job who was going to put in a twin link on a damaged chassis.  Paint both sides (engine room and wheel arch sides) with the stuff...doubt the current owner even knows that there are patches in the body...
« Reply #12 on: Tuesday,August 08, 2023, 12:13:42 PM »
That looks good too Bryan!
« Reply #13 on: Tuesday,August 08, 2023, 01:19:07 PM »
Disappointed to find that the Blue/Grey Zolotone I bought in the past is no longer readily available.
Other colors can work but I am searching for the Blue/Grey.
