Author Topic: S1 Coil Overs  (Read 531 times)
Offline My S1
S1 Coil Overs
« on: Sunday,July 30, 2023, 02:41:21 PM »
Does any one know who is assembling these S1 coil overs for Dave Bean et al?  I have been unable to purchase them from DB and would like to go straight to the source.
Re: S1 Coil Overs
« Reply #1 on: Sunday,July 30, 2023, 04:18:29 PM »
You might have a hard time. I know Protech makes shocks that fit but don't sell it with the sway stud in the bottom but you can get them from SJS with the stud.  https://www.sjsportscars.com/parts-and-accessories.htm#searchresults
Protech sells a double adjustable too but SJS doesn't list it.
I don't know about Spax or or others selling direct with the sway bar mount.
Re: S1 Coil Overs
« Reply #2 on: Sunday,July 30, 2023, 04:50:01 PM »
Protechs use 1 7/8” springs.
r.d. sells SPAX. I believe their fronts have the stock sized spring perches (2 1/2”?).
Lotus Supplies sells AVO. I think all their shocks take 1 7/8” springs.
Dave Bean used to sell SPAX but I don’t know if they still do.
You should expect that all the front shocks these suppliers sell will have the requisite anti-roll bar mounting stud.
Re: S1 Coil Overs
« Reply #3 on: Sunday,July 30, 2023, 04:54:50 PM »
Dunno what shock Bean sells.  AVO, Spax, GAZ and others have shocks for Europas.  What f you know what spring rate and length you require, great.  If you are not sure, I would recommend going to a Europa specialist.
Myself, I got my S1 shocks from Banks/Lotus Supplies.  I specified AVO units with as close to stock springs as possible.  Mostly worked well.  Only trouble was with the poly bushes which perished rather too easily.  AVO sent another set free but they didn’t last either so I switched to Merlin Motorsport’s HD bushes for AVO shocks and have been trouble free ever since.
I specified stock springs as I wanted a good ride for my primarily street driven car.  Perfect! Best riding car I’ve ever ridden except for 60s and 70s Citroens.
Re: S1 Coil Overs
« Reply #4 on: Sunday,July 30, 2023, 04:56:22 PM »
One further note, S1s, and early S2s, must have the narrower springs as the wider springs don’t fit in the available space.
Offline My S1
Re: S1 Coil Overs
« Reply #5 on: Monday,July 31, 2023, 09:09:05 AM »
Thank you gents.  I'll look into Banks with the Merlin bushes.
Offline My S1
Re: S1 Coil Overs
« Reply #6 on: Monday,July 31, 2023, 06:38:35 PM »
John,  are the Banks coil overs that you bought black?
Re: S1 Coil Overs
« Reply #7 on: Tuesday,August 01, 2023, 11:42:00 AM »
Yes, I think most/all AVOs are black.
