Author Topic: No start on 54-1173  (Read 3043 times)
Re: No start on 54-1173
« Reply #30 on: Monday,July 03, 2023, 05:40:41 AM »
Has the cylinder head been off?
Offline Gary t
« Reply #31 on: Monday,July 03, 2023, 07:36:11 AM »
Not in my time. I have driven the car about 2000 km in the past couple of years.
Gary Toffelmire
54/1173
« Reply #32 on: Monday,July 03, 2023, 08:34:33 AM »
Is something bottoming and preventing the distributor clamp from tightening properly?
Offline Gary t
« Reply #33 on: Monday,July 03, 2023, 10:07:32 AM »
That was my thought also but I am in the  process  of putting the dash back together after the ammeter extraction.  I replaced the ammeter electrically with a 40 Amp fuse,  the ammeter shunt gave its life to save my car.
Is removing the distributor a big deal (assuming I can replace it in same orientation)?
Gary Toffelmire
54/1173
« Reply #34 on: Monday,July 03, 2023, 10:24:35 AM »
It's easy.
Mark the original position, remove the nut & clamp and it just lifts out.
There should be no clearance between the dizzy flange and the head.
« Reply #35 on: Monday,July 03, 2023, 03:49:43 PM »
Quote from:
[/quote
  Gavin, Isn't there a gasket under the distributor?  I dropped one on just as a security blanket for oil leaks, but still able to stop movement of the distributor. so zero clearance would be correct, don't get me wrong, just tight. remember I'm a novice on these engines.
dakazman
Offline Gary t
« Reply #36 on: Monday,July 03, 2023, 04:16:58 PM »
Well another answer yes it is the distributor.  When I removed it it was totally locked put pliers on the drive gave ita wiggle and it started to turn but all rattley and catching so I assume  a whole new unit is in  my future.
Any suggested suppliers or parts sources or the best way forward.
Gary Toffelmire
54/1173
« Reply #37 on: Monday,July 03, 2023, 06:12:46 PM »
What do I win?  ;)
« Reply #38 on: Monday,July 03, 2023, 06:31:29 PM »
What do I win?  ;)
You win the most valuable thing, internet points  8)
« Reply #39 on: Monday,July 03, 2023, 07:18:08 PM »
Ignition123 make a new programmable distributor.  Handy if you modify the engine but not cheap.
If you are not in a rush, you can send it to me and I’ll overhaul it for you.  I’m in Edmonton and I have a distributor advance machine and the necessary machine tools.
Offline Gary t
« Reply #40 on: Monday,July 03, 2023, 07:34:15 PM »
Thanks John I'll keep your offer in mind. We are away for a couple of weeks I'll  see what jells in that time.  What is your  definition of not in a hurry?
Gary Toffelmire
54/1173
« Reply #41 on: Tuesday,July 04, 2023, 07:50:34 AM »
It's summer and I'm busy with fun so a couple of weeks?
« Reply #42 on: Tuesday,July 04, 2023, 07:53:14 AM »
PS: I'm offering because you are, relatively, close-by.  Only charge would be for any parts and shipping.  Worst I can see is a couple of brass bushings.
Offline Gary t
« Reply #43 on: Tuesday,July 04, 2023, 04:22:32 PM »
Thanks so much for the offer John.  We are away for two weeks so no shipping of anything  until I am back home.  As you say this is fun season I have emailed the usual suspects, I will keep you posted.
I didn't take anything apart but it will need a new drive lug other than that I don't know.
Gary Toffelmire
54/1173
« Reply #44 on: Tuesday,July 04, 2023, 06:55:39 PM »
dakazman
Dave, there's no gasket as far as I know – and it doesn't seem to weep oil.
Just be aware a gasket would inevitably affect the dog engagement in the dizzy drive adaptor.
